Old 10-03-2016, 09:17 PM   #1
Added 3rd A/C to 35ROK
Having read several threads on this subject and specifically the one that Brad published inspired me to go for it. 95 degree days in the South and not being able to get the inside temp below 82 degrees after considerable work to seal ducts, installing sun blocking blinds, pillows in vents and minimizing door opening I decided it was time. The total job took about 2 days and $800.00, one day for wiring prep and one day to install equipment. Having the CCC 2 thermostat and 2 zones factory installed made the job easier. Zone 3 which I installed by removing the rear vent and installing the Dometic Brisk Air 2 15.0 with a non-ducted T-stat controlled air distribution box. I did a hybrid install by tying in the non-ducted air distribution box to the factory installed ceiling ductwork (not difficult) and the overall effect gave me more air without running additional ducts which would have been difficult. Available electric power is a non-issue, all 3 units running and the fans on hi and I wasn't close to maxing out. Indoor 68 degree temps are now achievable. Hardest part may have been running the telephone cable for thermostat com (4 wire flat cable) from zone 3 at the rear to zone 2 in the front bedroom (about 35 ft), make sure you follow wiring diagram for installing the connectors on the ends.
ingalmi is offline   Reply With Quote
Old 10-03-2016, 09:54 PM   #2
chop249's Avatar
You should post pics here and to Brad's thread. I'm waiting on my unit to come back from warranty repairs to see if they actually fixed the A/C (doubtful but fingers crossed anyhow) before I do the 3rd unit. I'm almost resigned to having to do it.
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 13
chop249 is offline   Reply With Quote
Old 10-06-2016, 08:15 AM   #3
I am adding this to my list to do as well. My issue is my wife works nights so the front bedroom is closed off all day. It gets plenty cold in there but the second unit can't keep up in the living room during the afternoon. I've seen In door temps as high as 88 in the living room. When we were in a shaddy spot there wasn't any issues, but now we are in the sun all day, with late day sun hitting the rear of the Trailer so it just bakes it.
Mikele is offline   Reply With Quote
Old 10-06-2016, 08:45 AM   #4
This off-season, I am going to add a 3rd a/c in my TT. I have the main a/c in the kitchen area and the 2nd a/c in the master area up front, however the kids' bunkhouse in the back can get hot when the temps are up there. The main unit is ducted, however it just doesn't do much all the way in the back.
A 3rd a/c will definitely keep the back cool. Total BTU will be overkill for the TT, but will leave me in total control of cooling.
For me, I don't have a vent/window in the back ceiling, so I will be cutting the hole and building the frame myself. I have already planned the electrical wire run.
I'll take pics and post when I do this. Fun times!
325BH is offline   Reply With Quote
Old 10-06-2016, 02:28 PM   #5
jtesta1's Avatar
hard part will be paying for the electric bill.
jtesta1 is offline   Reply With Quote
Old 10-06-2016, 08:44 PM   #6
chop249's Avatar
What campsites charge electric in addition to the regular camping fees????
Bob
Old 10-06-2016, 09:06 PM   #7
Mr. Dan's Avatar
There's one in Schulenburg, TX that does... has a meter at each site... only one I've seen.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 42; booked = 20
Old 10-06-2016, 09:25 PM   #8
You really need 68 F in your trailer???!!! I keep my house at 78 F. Once you've removed the moisture, you really don't need temps that low.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 10-07-2016, 07:17 AM   #9
Wolverine 1945's Avatar
We keep our home around 74,,, had our A/C replaced a couple of years ago,,, new unit is bigger than our old one,,, and it does a much better job of removing humidity,,, so 74 is pretty comfortable !!! I would have to wonder how many amps would 3 A/C units draw ??? And would a de-humidifier work as well as a 3rd A/C unit ???
Wolverine 1945 is offline   Reply With Quote
Old 10-07-2016, 08:25 AM   #10
I full-time, and almost every CG I've stayed at in the last 2 years with the exception of the one I'm currently in has charged for electric.
