02-20-2017, 08:26 AM
#101
Originally Posted by brad2388
Yea i know! At the rate its going we will need to add a 4th!
Ha ha! You better knock on wood! I'll leave it parked and stay in a hotel before that happens.
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 21/18 = 11
03-30-2017, 09:02 PM
#102
All of the parts except the remote thermostat have arrived. Have not ordered that yet. Hoping to get started this coming week.
04-22-2017, 08:03 PM
#103
Ok. If the rain keeps up and baseball is cancelled tomorrow, I'm gonna get to work.
Work has be crazy this year. Have logged 135K AA miles and have only had 3 weeks that I have not traveled. Gotta get this done before going back to Taiwan in 2 weeks!
04-22-2017, 08:05 PM
#104
Wow!
Guess thats a good thing. At least better than the alternative. Sitting at home.
04-22-2017, 08:09 PM
#105
Wow!
Yeah. It's been crazy.
I have everything sitting at home for the install except for the thermostat. I'm hoping I can make some progress tomorrow. Really want it done before Memorial Day. We are camping at Myrtle Beach then.
04-23-2017, 10:26 AM
#106
Are you going to document everything in detail so I can copy?
Jay
TV:2012 Tahoe
TT: 2012 Grey Wolf 25MB
Other Ride: 2006 Harley Ultra Classic
04-23-2017, 10:27 AM
#107
I will try. I'm gonna get the wiring ran today.
04-23-2017, 11:09 AM
#108
Good luck! I look forward to seeing the results!
Jay
TV:2012 Tahoe
04-23-2017, 02:41 PM
#109
Well.... some progress before having to stop for other chores.
I have a book case that pulls out accessing the plumbing for the tub. By removing it, I have clean access to get the wiring from the ceiling to the basement (for connecting to the breaker panel).
I started with the CAT5 cable. I need to get it from the front AC to the "book case access point" in order to tie it in with the Romex. I managed to get it from the AC to the forward light (wrong direction from where it will ultimately run). From there, I need to get a fish tape from the access point to that light. The preferential bend in the old school fish tape I have seems to cause it to hit an obstruction about half way that I can't get around. That is where my work has stopped so far. I'm gonna head to the store later and pick up a set of those fiberglass wire pulling rods as I believe I will be able to position them a little better to get below the obstruction. I know there is a way through it, as There are other wires that run below it to from light to light.
I am not sure what circuit I will wire it into, but leaning towards the W/D. Aside from the fact that we have no plans of adding one, it seems to be one of the only labels that were written so that the user can read. I am open to any input from the readers on this.... thoughts?
04-23-2017, 04:55 PM
#110
Attachment 135624
Attachment 135625
Attachment 135626
Attachment 135627
Attachment 135628
Great stuff. Anxious to see if you are able to get that wiring through. I don't currently have plans for w/d either but think I will put a new breaker in just in case.
What did it take to pull the bookcase? And why did you have to go backwards to the light?
Is your breaker panel next to the first step in the hall/stairs leading to the master bed too as it is on mine?
Once you get wired into the cavity, where are you taking the run to the back of the camper for the new a/c?
Again, thanks for documenting everything. I will owe you when I start to tackle mine!
Jay
TV:2012 Tahoe
04-23-2017, 05:04 PM
#111
Just watched a video tour of your model. Completely different floor plan except the master room is exactly the same. Fuse panel is the same too. I'm guessing most of the work will be the same for me which is good.
Jay
TV:2012 Tahoe
04-23-2017, 05:40 PM
#112
Attachment 135624
Attachment 135625
Attachment 135626
Attachment 135627
Attachment 135628
Harbor Freight has a pretty good deal on the rods if you have one close.
My electric box was labeled by Stevie Wonder.
2017 Puma 297RLSS
04-23-2017, 05:42 PM
#113
The book case is held in with 4 screws. I already had it out as I am also replacing the vacuum breakers for the black tanks. I went backwards because all of the other wiring exited that way. Seemed like the easiest approach versus drilling another hole or routing out the rear where the duct work was.
Yes. It is right at the first step.
I think I am going to across near the Curb side, and then down from light to light that way. That avoids the cabinets and shower, and also provides a light hole (for access) every few feet.
More to come tomorrow.
04-23-2017, 05:43 PM
#114
Yep... I just picked some up about an hour ago. $6.99 for 10 pieces (11' total).
04-24-2017, 12:16 AM
#115
That is soooooo wrong! Funny as 7734 though! And if you get that reference you're old like me!
Bob
04-24-2017, 12:23 AM
#116
Attachment 135624
Attachment 135625
Attachment 135626
Attachment 135627
Attachment 135628
I see:
Water Heater
Washer/Drier
Fireplace
(Maybe) Audio / Visual ???
Microwave
Main
Main
Microwave #2 ???????
BLANK
Refrigerator
If I get a minute I'll look at my panel and see if it helps decipher yours.
Bob
04-24-2017, 09:00 AM
#117
I sent a note to Jeffery Johnson asking if he could decipher the writing. I'll see what he says if he responds.
04-24-2017, 11:19 AM
#118
The fiberglass rods did the trick. If you are planning to do this, I suggest getting the very short rods.
Came in for lunch so decided to post an update.....
After getting the Cat5 to the access point, I then decided to get the romex close to the panel to connect later. I started in the access point by feeding the "bottom" of the cable through an existing hole.
I the went to the basement and removed the "walls" the hide the inverter and Heater.
From there, I was able to pull the Romex to the outside world....
I then went inside to the steps and removed the grill on the second step and pulled the romex through.... I left enough to later route behind the wall and out the panel.
Back to the access point I went. I spent a few minutes figuring the best next step. While I probably chose wrong, I decided to go under the duct work and get to the lights on the curb side. To do this, I removed the light in the bathroom and ran the fish rod back to the hole in the access point. I secured the cable ends and was able to pull them through.
From there is was just a short shot to the light in the hallway.
After lunch I plan to pull all of the wire through into the hallway. I feel like this will help me get a straight shot back to the bunk room with the least resistance. Try to continue to work with the slack in the access point seems like it could cause the cable to pull on other wiring as i work back.
The biggest issue so far has been able management while pulling. Without the cable in a box / reel, it would help to have someone paying the cable off of the coil.
More to come later. I see the light at the end of the tunnel now.
04-24-2017, 02:07 PM
#119
Attachment 135746
Attachment 135747
Attachment 135748
Attachment 135749
Attachment 135750
Attachment 135751
Great stuff. Thanks for the updates!
Jay
TV:2012 Tahoe
04-24-2017, 02:34 PM
#120
Well.... have the wire and Cat5 where I want it for now. I managed to get it into the light hole in the bunk room where it will stay until I get ready to actually install the AC.
Running the wire through the living room was straight forward. Tedious, but straight forward. Getting from the living room to the bunk room was more challenging, as there was a piece of wood that supported the duct, and the bunk light was on the other side of the duct. I'm had to feed the rod from the living room to the bunk room, and then reach in the light hole (almost elbow deep) and grab it to pull it towards the light. At that point I realized that I ran the rod the wrong way. Knowing that it would be another luck shot to get it back in there, I improvised..... I zip ties and taped the crap out of the wire to the wrong it of the rod. I then managed to get it through without it breaking loose. Score!
Before I put the basement walls back, I am going to install two cable outlets. One for the DTV splitter at the docking station, and one near the existing cable outlet. This will hide my splitter and basement satellite cable.
That's all for now. I'm headed out of the country tomorrow and will be back Friday. Unfortunately, we have a baseball tournament this weekend so I'm not sure that I will get it finished. I'll update as I progress.
Any questions, ask away.
Oh yeah. Next project is installing the hitch for the swivel wheel and running a dedicated satellite cable behind the basement
