Old 08-25-2012, 11:53 AM   #1
Air bed leaks, first time we used it
Now what. How do you find a leak in these things. Will they warranty it. My poor brother uad to run the pump every hour last night.
karznromz is offline   Reply With Quote
Old 08-25-2012, 12:29 PM   #2
davidjb's Avatar
same thing happenned to me the first time I tried mine, turns out it was a staple sticking up and yes my dealer got me a new one no problem. Had it shipped to me. I had to give them the old one.
davidjb is offline   Reply With Quote
Old 08-25-2012, 12:49 PM   #3
Herk7769's Avatar
Three possible fixes; Two easy and one takes some sleuthing
1) Look at the air dump valve at the foot of the mattress (opposite from the air pump). There is a yellow tab on the flap under cap. If someone sits on the end of the inflatable mattress, the flap can pop open. The cap is not perfectly air tight and relies on the internal flap to hold in the air. Pull the yellow tab until it locks and reflate and test.
2) A small hole: If you look at where the hinge points of the sofa back are you will see where it might have gotten pinched when being put away. I used a bike tire patch kit and fixed mine. 3 years later still going strong.
3) Call or email Flair. They will replace the mattress with a new one if still under warranty. They will sell you a replacement far cheaper than a Coleman air mattress of the same size. Flair Interiors: Sleep and Store Sofa System
HAM CALLSIGN - KC3FFW
Old 08-25-2012, 04:28 PM   #4
TTNewbees's Avatar
I took mine to general rv(my dealer). 3 days later a new one showed up at the door by UPS/FedEx.
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 08-25-2012, 05:05 PM   #5
wfmdfm's Avatar
On other thing to check that was an issue for us a few weeks ago is the fill plug on the end. It was loose and we were loosing air all night. Just twisted it tight and it was solved.
Wally
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 08-25-2012, 05:24 PM   #6
kirk37r's Avatar
Do your self A favor, Air it up and use A solution of dish detergent and water to lighly spray it. The detergent will bubble at the smallest leak. If no leaks then take the cap off and put 2 layers of seran wrap over the hole and retighten the cap. Last make sure that the arrow on the inflater is lined perfectly with the triangle on the switch.
We had A leak in ours the first time we used it. Yes it had been pinched by the frame of the couch. Patched it with the provide patch and glue. But it still leaked down slowly overnight, Put the seran wrap on the deflate whole and we are good.
I Must say we gave the air mattress in our 08 Cedar Creek A lot of use and never had A problem with it leaking, But these new ones they use now sure seem to have A lot of issues. Man I wish they still made them like the one in our old 2008.
Kirk, Carol& Nicholas (Grandson)
2013 Cedar Creek 38FL, RV Cams rearview cam
2012 Ram 3500 DRW
CAUTION behind this truck is A contagious disease!!!
Its called Camping!!!
kirk37r is offline   Reply With Quote
Old 08-25-2012, 11:54 PM   #7
Brush's Avatar
Flair Interiors replaced mine twice while under warranty.
Bill and Darlene
2008 Tundra 5.7, 4.30 axle, 8' Bed, 4WD, Super Springs
2009 Rockwood 8319SS Reese WD hitch
Nights camped in 2018(0) 2017(25) 2016(31) 2015(34) 2014(37) 2013(36) 2012(37) 2011(21) 2010(48) 2009(33) 2008(18)
Brush is offline   Reply With Quote
Old 08-28-2012, 04:08 PM   #8
golfmedik's Avatar
Wally
Same here on our Myrtle Beach vacation. Just tightened the plug and all was well.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
bed
