Old 02-13-2016, 02:47 PM   #11
What brand of TT? Kind of looks like a Vibe... Should probably check mine!
2016 Vibe 268RKS
2015 Chev 2500HD
Mewcasa is offline   Reply With Quote
Old 02-13-2016, 05:04 PM   #12
chop249's Avatar
Sandpiper.
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 21
chop249 is offline   Reply With Quote
Old 02-13-2016, 06:55 PM   #13
Hi hope the repairs happen in a timely fashion. I have some questions about what happened when the fridge did the face plant into the couch.
1. Were the propane tanks turned on or off when this happened?
2. If propane was on was the fridge turned on?
3. Did the propane lines fail when the fridge fell over?
The reason I am asking these questions is that there has been a lot of discussions in the past on this forum about running the fridge on propane while driving to your next destination.
Tim
TimVWulp is offline   Reply With Quote
Old 02-13-2016, 07:07 PM   #14
Tim
Looks like a residential refer not a regular propane RV type. Many new RV have gone to the residential types.
Georgetown XL 377TS
USAF-- CMSGT Retired.
georgew48 is offline   Reply With Quote
Old 02-13-2016, 07:10 PM   #15
SternHappens's Avatar
Curious how long you've had the unit and how many miles it has on it, that it didn't happen your first time out, or the drive home from the dealer for that matter.
SternHappens is offline   Reply With Quote
Old 02-13-2016, 07:25 PM   #16
Plain Old Member
We put our own residential in last year. In doing so, across the back / bottom framing, I put 4 long #12 screws. Of course you can only do this if you have an access panel to the back of the fridge. Some manf. are kind enough to do so. At the inner top, I riveted L-brackets to the top of the fridge, then secured those into the cabinet framing once the fridge was in. The brackets are hidden by trim. I've seen some of the factory "securing", and it was less than on par. Always good to check if you can.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 02-13-2016, 09:18 PM   #17
chop249's Avatar
Tim
Residential unit, runs on an inverter. Our last RV had the propane unit style. We ALWAYS ran the propane during transport.
I've got about 2500 miles on the unit according to my mileage tracker on the truck. Didn't drive any different than I had driven the other 2000 plus miles. The only difference I noticed was the road. The tollway we took had some spots in it that made us bounce. Nothing severe but certainly noticeable and definitely not enough that I would have expected this.
Bob
Old 02-13-2016, 09:21 PM   #18
chop249's Avatar
Guess I should add I have over 20 years of trailer experience. This is my first 5er but I don't think that should matter.
Bob
Old 02-13-2016, 09:37 PM   #19
SeaDog's Avatar
Thats really poor that they didn't fasten that frig inside the wall cabinet as they should have. Hold their feet to the fire and no matter how minor the damage make them fix it like new.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-13-2016, 10:00 PM   #20
VinceU's Avatar
Originally Posted by chop249 View Post
Minor warrantee issues till today..... The fridge decided to fall over en route to a campsite. Anyone ever have this happen?
Name:	ImageUploadedByForest River Forums1455422177.522557.jpg
Here's a good setup, two flat bars flanged to wall with backers, inboard end screws to hinge plates on reefer. Very solid.
