Old 02-23-2015, 12:36 PM   #11
Found problem. Both sinks vent from under sink above ptrap with a check valve looking device. Evidently when tank fills past a point if almost full the device closed and allows no venting or any water out. So it gurgles down. Can still use shower for about 5 gallons then all is full.Dumping gray tank restores every thing to normal.Not a big deal was curious. Our unit has both sinks on slide so not connected to any roof vents.
Jackfacente is offline   Reply With Quote
Old 03-14-2015, 12:19 PM   #12
That happened to me only it was the shower. I don't know where it came from but I had a river going down the stairs. I emptied the grey tank and all was well until hubby came back from fishing. He wanted the grey water to clean the hose.
KathyJB is offline   Reply With Quote
Old 03-14-2015, 02:50 PM   #13
[/URL]
contractor Rob is offline   Reply With Quote
Old 03-14-2015, 02:50 PM   #14
Bathroom sinks full, gray tank not.
Originally Posted by contractor Rob View Post
[/URL]
Check your vents on the Roof
roo, tank
