Old 03-21-2015, 06:31 PM   #1
Beginners Checklist
Ok here is the list of stuff I am collecting before my Fifth is due in. How does it look am I missing anything?
Black Water / Sewer 20' Sewer Hose Kit 10' Sewer Hose Extension 20' Sewer Hose Support 50' Hose (Black Water / Misc) 45deg Sewer Hose Clear Adapter Sewer Hose End Caps (2sets) Hose End Caps Fresh Water 50' Drinking Water Hose 25' Drinking Water Hose Water Regulator 90deg Hose Adapter (2) Y Hose Connetor Hose Washers Hose End Caps (2sets) Electric 50amp Surge Protector 25' 50amp Power Cord 50amp Power Cord Extention 50amp-30amp Adapter 50' Extension Cord Surge Protector Lock Box
Jz5g52 is offline   Reply With Quote
Old 03-21-2015, 06:34 PM   #2
Sorry it was suppose to be a easy reading list site ignored the returns
Old 03-21-2015, 06:55 PM   #3
Canadian Member
itat's Avatar
If you read this forum long enough you'll find a way to double what you've spent already.
You've got a good handle on it. What do you plan on using to level the 5er (side to side)? I just use 2x8 pressure treated wood planks. They're a lot cheaper than the plastic stacking Legos but they take more storage space and can be heavy when wet.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 03-21-2015, 07:03 PM   #4
Thanks forgot all about leveling and chicks do you need the tripod for the pin box I think it is to stabilize?
Old 03-21-2015, 07:15 PM   #5
Canadian Member
itat's Avatar
Sorry, I can't help you with the tripod. I've never owned a fifth wheel. Everything else on your list is common to travel trailers.
Old 03-21-2015, 07:23 PM   #6
Rather than lego blocks or wood, would suggest a pair of Anderson Levelers and some type of JT Strongarms instead of a tripod.
Old 04-26-2015, 04:32 PM   #7
Time-Travelers's Avatar
Extra fuses
Time-Travelers is offline   Reply With Quote
Old 04-26-2015, 05:42 PM   #8
dap
If I read this right you are planning on buying a power cord going from trailer to campground electric,this should come with the camper.
dap is offline   Reply With Quote
Old 04-26-2015, 06:31 PM   #9
Here is a checklist of things you will need and it includes pretty much EVERYTHING you could possibly need for a trip.
RV.Net Open Roads Forum: Beginning RVing: Stocking an RV
merrykalia is offline   Reply With Quote
check list
