Old 08-22-2013, 07:55 AM   #11
golfmedik's Avatar
No drawings. If you do a search on here and on RV.net you will find the step by step instructions I used when I did it. If I can get to a computer, I will try to share the link. Only on phone for a while today.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 08-22-2013, 04:56 PM   #12
Just another idea that we do.We carrry three bikes where dinnete is.We took cushions off and put three kleets for the forks of the bike on the wood under cushions.We carry three there and the fourth one is on the bottom bunk ,again held tight with a fork kleet.I like this set up because it keeps the bikes dry and it seems to rain every weekend we camp!Anyways works great and takes ten minutes to load bikes.When we unload bikes we just flip the dinnete wood seat over and put cushions back on.No need to remove fork kleets.
Rtazz17 is offline   Reply With Quote
Old 08-22-2013, 07:27 PM   #13
golfmedik's Avatar
Here is a link to this site's write up: My pin box bike rack with pics.
And here it is on the other site: RV.Net Open Roads Forum: Fifth-Wheels: Pin Box Bike Rack Source
Old 08-22-2013, 07:34 PM   #14
AquaMan's Avatar
If it looks like rain, or I'm traveling a great distance, I will usually pull the seats off before I load the bikes, and store them in the basement.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 08-22-2013, 08:02 PM   #15
Dont get me wrong,its not just a rain thing.I just like to have them secured inside when traveling.I like the bike rack on the nose but its just not for me.I think I would lose my mind if I had a billion bug guts all over my bikes.Lol.With my luck the rack would end up going through the nose of my camper or my cab rear window.I have a shortbed and I am at 90 degrees pulling into my driveway at times.I just thought I would give another option.I should post a picture of setup.Cost 50 bucks for the kleets.
Old 08-22-2013, 08:06 PM   #16
AquaMan's Avatar
I see your point, but I look at it like, I would rather have bug guts on my $400 bike than on my $40k 5ver.
Old 08-22-2013, 08:10 PM   #17
Yeah but I guess you could call me a clean freak with ocd...I would end up spending two hours cleaning the bikes when getting to CG... Nose of camper is simple to clean..
Old 08-24-2013, 09:49 PM   #18
kerrlakelover's Avatar
Been doing some serious research and hope this helps everyone.
1. Lippert manufactures the frames for the Sandpipers (and many others). I discovered that Lippert has an online store and they have bike racks and receiver hitches designed for our FWs and TTs. (Lippert Component's RV Parts & Accessories / Storage, Towing, and Convenience / Bike Racks & Receivers) The rated weight is still very limited (for the most part 250lb max). I talked with the Customer Service folks at Lippert and their products were their only recommendation. The racks and reciever are pretty pricey and I would advise you to call Lippert and ask them to tell you exactly which rack or receiver you need for your particular FW/TT.
2. Curt mfg also makes an "adjustable width trailer hitch reciever" specifically for RV FWs and/or TTs. It expands out to 72" wide (my Sandpiper measures 60+" at the frame extensions that connect to the bumper). This hitch is pricey to and is $322 on etrailer.com (Adjustable Width Trailer Hitch Receiver for RVs, 22" to 72" Wide Curt Specialty Trailer Hitches 13703) I found it for $250 at my local Leonard store (Leonard Buildings and Truck Accessories).
3. If you look at your FW or TT frame, the frame rails are not really heavy gauge steel. So, even if you get the Lippert products or Curt products, I would caution you to put anything much over 200lbs on either of them. And don't forget (as many of our fellow FRF friends have said on many posts on this subject) if you have a bike rack that sticks out of the receiver hitch 3-4 feet with 4 bikes hanging on it, the law of physics takes over and the leverage of the rack sticking our 3-4 feet will definitely really increase the "weight and torque" that is applied to the frame rails. So, just because you mount a big honking receiver hitch back there, you still better be very conservative on what you hang on it. And NEVER underestimate the forces that effect anything on the back of your FW or TT. It's like riding in the very back seat of a school bus.
So, after all that, here's where I'm at with hanging stuff off the back of my 2010 Sandpiper 345RET.
1. I feel very comfortable that either of these hitches will carry the load of our 2 very light frame mountain bikes.
2. My plan to mount 2 eu2000i Honda gens on the back of my Sandpiper is tentatively looking like this. I will probably pick up the Curt hitch for $250. Next, I will have a local fabricator build an aluminum carrier 65-70" wide and deep enough for the gens to just sit in the carrier. Next, I'll have a 2x2" tube fabricated that comes out of the receiver and turns up and sits right on top of the back bumper (no weight on the bumper). I will also fabricate something (let's call them spacers...maybe 2" pieces of rubber) to put between the carrier and frame extensions (bumper is welded to this) to just keep the carrier from rocking from side to side. Very minimal weight will be on these "spacers".
3. I will never carry both the gens or bikes. I will carry one or the other.
4. And no, while it's great for some of you, I just don't like hanging bikes off the pin box. My kids call me "Mr Anal"....for me, I don't like the way it looks.
What do you guys think about my tentative plans?
kerrlakelover is offline   Reply With Quote
365, 365saq, bike, bike rack
