Old 06-07-2012, 10:49 PM   #1
Bunk house slide out problem
I have a 08 sand piper 5th wheel with a bunk house slide. I notice that the top left side of the slide is against the weather seal and has torn it. I have adjust the slide screw to see if that would help but it seems to be still closer on the left side than the right side. Is there something else i can check?
Forsythofficer is offline   Reply With Quote
Old 09-26-2012, 10:03 AM   #2
Grums's Avatar
We seem to have the same problem in our 2012 Blueridge 3600RS. When the slide is out, there is obvious signs of wear and now the seal is torn but not the rubber flange it closes into.
Did you get this solved and if so how? Thanks.
Grums is offline   Reply With Quote
