bypassing Lippert one control
Our Lippert One Control panel has stopped working. I would like to be able to run my slides manually since the touch pad doesn't work. When I checked the owners manual is said there is a switch with up/down arrows to run the slides as well as a manual crank that can be drill driven. I found the port for the drill but cannot find the switch. I have full power to the rv so I would like to use power to run the slides. Can anyone tell me where I would find the switch. I have a 2019 Sandpiper 378FB.
