Old 06-22-2015, 08:56 AM   #1
Change outside fridge to LP?
We have a 365SAQ with the outside fridge. Has anyone found a refrigerator that runs off LP propane? Would be nice to keep it cooler when I don't have full hookups and can't run the generator. Kids seem to be in the fridge all the time
jkdairy is offline   Reply With Quote
Old 06-23-2015, 05:48 AM   #2
Herk7769's Avatar
The issue here is heat disposal.
While replacing the fridge with a propane one may seem a good idea, finding one that had a way of dumping all that heat to the exterior of the unit would be problematic.
The cooling coils are on the back remember and the airflow needs to start below the unit and exit the top.
Might be "do-able" if the exterior fridge was not in a slideout by cutting large rectangular hole in the floor below it and building a chimney flue up to the roof; you would still need to be able to access the rear for service so a hatch inside would be needed. Additionally, you would need to be concerned with the fire hazard as a "hard light" could cause a fire you would not be able to see in time to put out.
So, no. That is why you won't see this offered.
HAM CALLSIGN - KC3FFW
Old 06-23-2015, 08:48 AM   #3
Thanks for the info. Guess I'll stick with the same refrigerator it came with!
Old 06-23-2015, 11:55 AM   #4
Herk7769's Avatar
Still a great idea; just not workable with propane technology.
Might be possible with piezoelectric cooling but not sure how much DC power would be needed.
Old 06-23-2015, 12:06 PM   #5
AquaMan's Avatar
An idea that may work for you, is a portable AC/DC refrigerator/freezer. I have a Wynter 85qt that will freeze and hold temps to -8F. Has digital temp control so you can use as a fridge also. Gets cold quick and uses very little power.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-23-2015, 01:40 PM   #6
Herk7769's Avatar
Engel-MT35F-U1-AC-Fridge-Freezer
Seems like it would be a better fit.
Old 06-23-2015, 03:39 PM   #7
AquaMan's Avatar
Might be a better fit, but I got my 85qt for 2/3(or less) the cost, and it fits nicely under my outside kitchen slide, which is always in the shade.
Old 06-23-2015, 04:14 PM   #8
Herk7769's Avatar
This one?
Whynter 85 Quart Portable Fridge / Freezer - Silver - FM-85G : BBQ Guys
fridge
