Old 05-23-2013, 08:52 PM   #1
Deadbolt question
Hi guys
The deadbolt on the main entrance doesn't engage all the way when turned...meaning it turns about halfway.
Inside the catch plate area the wall is in the way....it is made if metal....so I could drill a hole in it, but then I have a hole....is the deadbolt itself adjustable?
tromler is offline   Reply With Quote
Old 05-23-2013, 08:56 PM   #2
Originally Posted by tromler View Post
Hi guys
How about some pictures? Would help.
Old 05-24-2013, 12:49 AM   #3
Twisty's Avatar
Pull on the door?
A pic or two would help.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-24-2013, 03:44 AM   #4
crunchman12001's Avatar
Hi guys
You cannot adjust the deadbolt itself but you can adjust the strike plate.
My last TT had the same issue but I was able to remove some of the exterior wall and foam behind the strike plate to get it to work.
Post a pic so we can see it.
crunchman
2015 F-250 FX4
Old 05-24-2013, 06:06 AM   #5
Hi Guys
Thanks, I will try to take some pics in a bit...but yes, the exterior wall (subwall) is in the way of where the deadbolt engages...so I think i need to remove some fo the wall to get a fully engaged deadbolt.
Old 05-25-2013, 03:48 AM   #6
golfmedik's Avatar
My 365 had some wood behind the strike plate that was keeping mine from engaging. A few minutes with a chisel and all is good.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 05-25-2013, 05:24 AM   #7
Herk7769's Avatar
Do you have a spring piston door holder?
I had one that was too strong and it was twisting the door out of plumb and the door deadbolt hitting the frame was my first indication something was wrong.
Turns out the factory had put a 20 pound piston on the door and it should have been a 10 pound piston.
Name:	Key West 2011 002.jpg
ID:	31291   Click image for larger version
Name:	Key West 2011 001.jpg
ID:	31292   Click image for larger version
Name:	Last Shots 044.jpg
ID:	31293   Click image for larger version
Name:	Key West 2011 006.jpg
HAM CALLSIGN - KC3FFW
