06-17-2019, 01:12 PM
Dometic Toilet water flow
I have a series 300 sanitation toilet that does not has insufficient water flow rate.I have had the toilet serviced by an authorized dealer but they claim they replaced the water valve but I still have insufficient water flow. Any suggestions?
06-18-2019, 08:48 AM
Welcome to the forum its a great place to get your questions answered. Domestic RV toilets are not like your household toilet in terms of water flow. How are you determining that enough water is not flowing at the proper rate? What I do is make sure there is water in the bowl before using to ensure a proper flush and hold the foot pedal only long enough to get everything down the drain. If you are having problems with stuff being left behind try putting in more water to start with.
Retired Navy
2016 Flagstaff 26 FKWS
06-18-2019, 12:49 PM
Thank you Seadog. I have resolved the water flow problem. Even though the dealer said that they replaced the water valve, it was not true. Took the water valve out and the valve was clogged with calcium build up. Order new valve and will go from there.
06-18-2019, 01:13 PM
Don't thru the old one away soak it in white vinegar that should clean it up so you have a spare.
Retired Navy
06-18-2019, 03:01 PM
Always Learning
You might find that this isn't the last time you have this. Those calcium deposits came from somewhere.
First, when you drain the water heater or the low point drains- make sure you first bypass the water heater. If it's a Suburban, it could be the source of these deposits. Emptying the low point drains without the water heater bypassed can suck deposits out of the water heater.
06-18-2019, 03:04 PM
Those water valves are easily cleaned.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
06-18-2019, 03:06 PM
Shame on them. At least now you know how much you can trust them.
06-18-2019, 03:11 PM
Always Learning
Or they did and it reclogged right away. Time will tell with the replacement...
06-18-2019, 03:16 PM
You could be right Doug.
Your advice about bypassing the water heater when draining the low point drains is spot on. Not doing so sucks the calcium deposits into the plumbing system where it is redistributed throughout the system on the next pressurization.
06-19-2019, 12:33 PM
On my unit I also had calcium buildup in the unit that sits inside the toilet bowl and directs the direction of spray. Took that apart as well and soaked in vinegar then used compressed air to finish off. Works well and is a easy fix.
Mike & Fay
2013 Rockwood 8289 Diamond with 3.5" lift
2017 GMC 2500HD Duramax
Curt A20 c/w GM Puck system
2021 56 night’s booked
06-19-2019, 01:23 PM
GM Mike,
I'm constantly having issues with minerals in the toilet valve. What do you mean you; use compressed air to finish off.? I'm wondering if buying a 310 toilet would get rid of the problem. I did have my water heater serviced and think they didn't do something right which is causing this mineral issue. Frustrating to say the least.
06-19-2019, 05:04 PM
Sorry. Just meant that I use compressed air to remove the vinegar and any chunks of remaining calcium once I finish soaking those parts. I had a small chunk of build up in that diffuser that wouldn’t allow water to flow into the toilet. I made 5 years before I had to do the cleaning so will be prepared for the next time.
