10-23-2016, 07:22 AM
Electric fireplace
Went to start up the heater on the electric fireplace this morning, the element glows for a few seconds then stops. Any suggestions?
11-09-2016, 06:48 AM
Check thermostat (heat setting) may be set too low. Read up on how to use the settings in your fire place owners manual.
11-09-2016, 08:06 AM
Sounds like the fireplace heating element tripped a circuit breaker in your RV.
11-09-2016, 08:20 AM
Does it do this every time you try to start the fireplace or did it do it once and now nothing at all?
11-09-2016, 08:25 AM
Everytime. I took the unit to a sandpiper dealer.
11-09-2016, 08:31 AM
OK. Well, let us know what they find.
It will help others who may have a similar problem.
11-09-2016, 08:48 AM
Mabee the wood is too wet. 😂😂. Sorry just had to.
11-09-2016, 10:43 AM
If you are a 50 amp service using 30 amp it may trip it off/ Fireplace draws lots of amps
11-09-2016, 10:55 AM
X2 - that was my thought exactly.
When we had our 5er (50AMP) we could not run our Fireplace + other items without tripping a circuit breaker.
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
11-09-2016, 11:03 AM
Most Rv fireplaces at max only draw about 12 amps.
Which is about the same as your water heat, microwave and a/c when its up and running.
Sounds like an issue with the fireplace.
11-10-2016, 07:31 AM
I got a call from the service dept, they said it was the blower motor. They are submitting the warranty claim.
11-10-2016, 06:00 PM
Makes sense. The blower has to operate properly to keep the heating element from overheating and burning out or worse. (kind of like water in a water heater) It obviously has a temperature sensing protection device that was working properly and shut down the unit as you experienced.
