Old 03-14-2016, 12:53 PM   #11
Tiggern2's Avatar
Every two years I get service tech to inspect all the gas, sorry as in propane appliances. Then adjust and clean if needed just to make sure all are working efficiently and safe. The other year I just check all propane vents outlets etc. For the usual before I test run them all.
Tiggern2 is offline   Reply With Quote
Old 03-14-2016, 01:52 PM   #12
Seals and New Hires
Nobody told the new hire how caulking is applied or where to seal. My competitive product was missing sealant around the rear window - whole back wall had to be replaced due to water damage - nothing fits together right the second time around (use lots of caulking to seal/hide misalignment). Thank goodness for the 2 year warranty.
DJsFolly
D. J. Schuler is offline   Reply With Quote
Old 03-18-2016, 09:07 PM   #13
Tiggern2's Avatar
UPDATE - our service / repair Center Got the new rear wall in place with wiring and rigid foam insulation. Everything is new. They also did rear truss ends and put new outer skin on after I left shop this am. Windows and trim next week.
Still not a word reply from Emails and photo sent to Forest River?Click image for larger version
Name:	ImageUploadedByForest River Forums1458353269.824941.jpg
Old 03-28-2016, 08:22 PM   #14
Tiggern2's Avatar
Work is on going on restoring our RV. The guys at Courtenay RV Specialist join the Filon skin at corners the way it should have been done at Forest River. Take note FR and learn how an RV should be built!!
Name:	ImageUploadedByForest River Forums1459214529.353888.jpg
ID:	103151Click image for larger version
Name:	ImageUploadedByForest River Forums1459214548.534025.jpg
ID:	103152Click image for larger version
Name:	ImageUploadedByForest River Forums1459214565.310169.jpg
Old 03-28-2016, 09:07 PM   #15
I go RV'ing not Camping
jgourlie's Avatar
Looks better than new
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
5th wheel, factory, led, sandpiper, wheel
