Old 03-18-2015, 12:33 PM   #1
Fresh water drain dripping?
It has started to drip and making a puddle under the rig. Has never done this before now. Had to prime the water pump two days ago because of air in system. Any thoughts on this??
Dave
2014 Sandpiper 35ROK
2004 Volvo VNL64T 630 left tandem
D-12 435 HP 740 CU
Western Golf and Country Cart (custom body, EZ-GO frame)
Arguing with some people is like trying to smell the color 9
Volvodriver is offline   Reply With Quote
Old 03-19-2015, 07:20 AM   #2
golfmedik's Avatar
Any chance that it froze and busted either the strainer or adapter on the pump? Are you sure that's where it is coming form is a better question?
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 03-19-2015, 08:10 PM   #3
arpipeliner's Avatar
Could be the overflow tube. If coming out a white tube around axles that's probably it. As the weather changes it can drain a little as it needs too.
arpipeliner is offline   Reply With Quote
Old 03-19-2015, 08:14 PM   #4
Had that happen to mine twice. Once it was the overflow tube and i just tightened it. Another time it was the hose clamp around the fill tube for the freshwater. tightened the clamp and no more leak.
motodude79 is offline   Reply With Quote
Old 03-20-2015, 03:23 PM   #5
Thanks for the replies. It was not frozen but I did have to re-prime as I mentioned. What I think is I have too much water in the fresh tank and have been releasing water from the fresh tank through the grey and galley tanks with the pump. It has been raining hard here in central Texas so will check again later today. It is not what I'd call a big problem, it's just aggravating.
Dave
D-12 435 HP 740 CU
drain, fresh water, water
