Old 04-10-2014, 11:34 AM   #1
Jacketsbum's Avatar
Fresh water tank
Ok so I went to sanitize the fresh water tank on my new ROK. far different from my old TT. The fresh water fill is threaded with a screen, ok no problem I attached a hose, but there is no vent, how do I know when the tank is full? How do I purge the air while its filling? How am I supposed to pour the bleach mixture in there with threads and a screen? I poured the mixture down the hose with a skinny funnel, surely there has to be an easier way! The only way I could tell if the tank was full was to keep hitting the monitor light inside the RV. Once again, is there a better way? With a vent it fills quick and when water squirts out its full! Not on this RV! What am I doing wrong?
2015 Sandpiper 35ROK
2013 Ford F-350 6.7 PowerStroke Diesel
2011 Mustang GT - Tuned and Lethal 475HP
2013 Chrysler T&C (hey ya gotta have somethin for mom!)
Days camped in 2014 - 33
Jacketsbum is offline   Reply With Quote
Old 04-13-2014, 03:12 AM   #2
They all fill a little different....mine has a valve underneath that I can open and close when I need to...
beau2portugal is offline   Reply With Quote
Old 04-13-2014, 05:59 AM   #3
There (HAS) to be a Vent on the Tank,if not it was forgotten! All your tanks need to be Vented. Youroo!!
Old 04-13-2014, 06:12 AM   #4
Ford Idaho's Avatar
Mine has a "overfill" vent tube next to the drain tube.
Water will start running out of it when the tank is "overfilled".
First time I ran water in the tank I got side tracked and forgot to shut the water off, came back outside and there was water all over the place which lead to instant panic mode before I remembered what the PDI guy told me.
Old 04-13-2014, 06:35 AM   #5
True but in his case filling with a (threaded 5/8 G/Hose and depending on a (3/8 vent hose) do the Math,something is going to Happen! Youroo!!
Old 04-13-2014, 06:39 AM   #6
Ford Idaho's Avatar
Mine is about the same size I have not seen or found any problems to date.
But at the same time I have a different trailer.
Old 04-13-2014, 11:49 PM   #7
Maybe you can use something like this? http://www.amazon.com/Jacks-Classic-...hemical+siphon
2013 365 SAQ
Rufinit is offline   Reply With Quote
Old 04-14-2014, 02:13 PM   #8
Jacketsbum's Avatar
I found the vent, it is a second tube coming out of the bottom. Kind of a dumb location if you ask me! Water sloshes out of there while you're moving and just keeps coming out until the tank reads 2/3 full. Going to put a shut off valve on there. Also the drain tube next to it has a screw on cap instead of a shut off valve, if you lose the cap or cross thread the plastic threads, you're SOL! Gonna put a shut off valve on there too!
Old 04-14-2014, 02:21 PM   #9
Witch Doctor's Avatar
You just have to stop and wonder sometimes what the s$$$ they were thinking about when they design this stuff. Every brand seems to have it's own weird problem.
Coachmen M/H
Concord
2018 / 300 DSC
fresh water, tank, water, water tank
