Old 05-31-2015, 11:39 AM   #1
furnace
Hello everyone sitting here in Michigan at 48 degrees and I thought what a good time to test the furnace, questions is have it hooked to the house can I run it off the house
Jz5g52 is offline   Reply With Quote
Old 05-31-2015, 11:40 AM   #2
fonzie's Avatar
Yes
Fonzie
Old 05-31-2015, 01:50 PM   #3
bikendan's Avatar
You do know that the furnace heats with only propane only, right?
Not by electric heat.
The only thing plugging into the house does, is keep the battery charged for running the furnace fan and electronics.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-31-2015, 02:22 PM   #4
Yes aware the heat is generate off the propane and the electric runs the blower just wasn't sure how much electric it pulled
On another question what about the fireplace with the heat will that run off the house plug Mize we'll try that out
Old 05-31-2015, 06:17 PM   #5
Old Member
The fireplace is 110 vac and will only work when the trailer has shore power. It has something like a 1200/1500 watt heater in it.
Cool Canuck is offline   Reply With Quote
Old 05-31-2015, 06:38 PM   #6
Thanks for all the response furnace and fireplace worked great, just air conditioning mirowave and cable left will test those next weekend maiden voyage when full hookup
Old 05-31-2015, 06:42 PM   #7
Ford Idaho's Avatar
You may check the micro now if you wish, while plugged in to 110 just put a cup of water inside and nuke it for 60 seconds.
furnace
