Old 03-03-2013, 05:23 PM   #1
Fw tank drain
I have a 2008 305rgs sandpiper and can't locate my fw tank drain. Help needed.
Thanks.
Horns07 is offline   Reply With Quote
Old 03-03-2013, 09:42 PM   #2
Dave_Monica's Avatar
You'll have to break out the creeper and have a good look under the camper...it's got to be there. It shouldn't be too far from the FW fill connection. You may as well locate the low point drains while you're under there.
Dave
Old 03-03-2013, 10:40 PM   #3
Probably looks like a small white faucet that's close to the edge so you can reach it. Should have a valve you rotate to open and drain.
