Old 10-31-2009, 07:48 PM   #1
heated tank switch?
we just purchased a 2005 37' sandpiper. there is a switch when on it turns red. i traced the wires down and it goes to a relay. from the relay the wiring goes down through the floor toward the tanks. i think this might be for tank heaters but not sure. can anybody help?
knorrick is offline   Reply With Quote
Old 10-31-2009, 07:59 PM   #2
Does it stay red or turn off. It is possible that it is the gas side of the water heater. My gas side water heater switch stays red until it lights then goes off. Just a thought.
Hokiehall is offline   Reply With Quote
Old 10-31-2009, 08:28 PM   #3
we have one of those also. this switch is beside that one
Old 10-31-2009, 10:34 PM   #4
NWJeeper's Avatar
Knorrick, these switches aren't labled? Ours says "Arctic pack" on it for the tank heaters, the other one "Water heater" for the gas side of the water heater like Hokiehall said, and one more that is for the water pump, also aptly named above it. All turn red when turned on. Not all rigs have tank heaters or the "Arctic package" as they are called by FR. It is an option which in most cases needs to be ordered. If you have 3 switches there I would guess that is in fact what it is for.
Ed & Wendy
www.nwjeepn.com
Old 11-01-2009, 08:14 AM   #5
Thanks for all your help. It was the switch for the tank heaters.
sandpiper
