Old 07-30-2015, 07:56 PM   #1
LryBrn's Avatar
Unhappy Help w/ HISENSE TV
I am trying to connect my BOSE system to the TV and cannot figure how to access the rear of the TV connection in the rear. I thought the TV would just slide off the mount to the wall but, I am having no luck. It seems rigidly fixed. Is there something I am missing...HELP PLEASE?
LryBrn is offline   Reply With Quote
Old 07-30-2015, 08:25 PM   #2
LryBrn's Avatar
By the way, it's a 2016 377FLIK
Old 07-31-2015, 10:02 AM   #3
If you're using optical connections it is on the left hand side of the TV and shouldn't have to move the TV out.
Sierra360PDEK is offline   Reply With Quote
Old 07-31-2015, 03:56 PM   #4
LryBrn's Avatar
It is not. It is on the rear f the TV. I wish it were that simple. I can't even reach back there to detach the unit.
Old 08-01-2015, 12:17 PM   #5
Hisense tv
I have a hisense TV and my hook ups are on the left hand side as you are facing the TV,They are hard to see,I have my bose solo hooked up there
rmayo38895 is offline   Reply With Quote
Old 08-01-2015, 12:55 PM   #6
LryBrn's Avatar
Is yours the42" or 50" HISENSE? My R. Has the 50" and from what I can tell they are not on the side. Argh!
Old 08-01-2015, 08:07 PM   #7
Mine is a 42
Old 08-01-2015, 08:13 PM   #8
Some mounts have a screw on the bottom of each of the TV brackets that has to be loosened to remove the TV .
LI Guy is offline   Reply With Quote
Old 08-02-2015, 06:45 AM   #9
SilverbackMel's Avatar
Have 42" in home bedroom. Hookups on left side. 2013 model.
SilverbackMel is offline   Reply With Quote
Old 08-02-2015, 06:51 AM   #10
RSchleder's Avatar
Why can't you simply look at the owners manual, as it will have a clear diagram of the rear of the tv which will clarify where all connections are located.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
