Old 08-16-2012, 01:30 PM   #11
TURBS's Avatar
Originally Posted by great white
bad?
why?
No ill intent meant.....
I know no I'll intent meant lol
I was goofing on u as well.
Old 08-16-2012, 01:51 PM   #12
Triguy's Avatar
Originally Posted by Jeanny View Post
Triguy,
Thank you!
I am still trying to find my way around. Where do I find the Sandpiper forum?
Jeanny,
It gets easier once you've been on for awhile.
You can find a list of subforums for "most" Forest River brands on the home page sorted by Motorhome, General Travel Trailer & Fifth Wheel, etc. Here's a picture of what you want to look for to find Sandpiper.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-16-2012, 05:10 PM   #13
Jeanny's Avatar
Originally Posted by Triguy
Jeanny,
You are so nice, Thank's again!
Jeanny is offline   Reply With Quote
Old 09-07-2012, 09:00 PM   #14
I had the same question. I just got my 340RL last week. I do have a switch inside the camper on a panel. As I'm understanding, that switch turns on the gas side of water heater whereas the switch on water heater itself (with pin through it) is to heat via electric. Can I heat via gas and electric at same time for reduced heat time (as I could on my past camper)?
cmulvey is offline   Reply With Quote
Old 09-07-2012, 09:28 PM   #15
B47
Question
Originally Posted by Triguy View Post
Jeanny,
Triguy - since this switch and the many other aspects/functions/questions/comments about it are almost always popping up here, would it be possible to make it a "Sticky" topic if it is not one already.
I am not sure what the rules are for making a topic a "Sticky", but perhaps this might quality.
Just a thought.
Old 09-07-2012, 09:36 PM   #16
TURBS's Avatar
Yes you may use both at the dame time.
Old 09-30-2012, 06:03 PM   #17
our Rockwood only has the switch on the water heater. our old hornet had a switch on the inside.
jerry1946 is offline   Reply With Quote
Old 09-30-2012, 06:45 PM   #18
VinceU's Avatar
Just a thought.
VG idea, there are tons of repetitive questions to operation and layup of water heaters.
Old 09-30-2012, 07:36 PM   #19
B47
Thanks for reminding me of this question. I asked Triguy about this back on 09-07 and he hasn't answered yet.
Old 09-30-2012, 09:10 PM   #20
jimh's Avatar
Hello every one,
My question is?
In our new 2012 Sandpiper 330RL FW
Is there a switch located anywhere on the inside to turn the heater to electric
Or just the toggle switch on the unit itself and the circuit breaker?
It is a Suburban SW6DE.
I have looked pretty much everywhere but can't seem to find one.
Thank you in advance for any and all reply's.
Jeanny.
a couple of different post told u parts of it. the switch in the picture (with the pin thru it) is to turn on the electric element. (the pin has to be removed to turn the element on...that way it can't be accidentally turned on). on my older trailer, the switch on the inside controls the gas side. u can run both. with both on if the electric element can't keep up, the gas will come on with it.
a caution, don't turn the electric element (or gas) on unless u know u have water in the hw heater. the element won't last very long w/o water. there is a releaf valve near the top side of the hw heater with a lever on it. pull that lever and make sure u have water. best to do this when cold.
on mine, i leave the outside switch on and turn it off at the breaker inside. (its easier for me to check the breaker when i have questions abt it being on or off). i do this each time before i disconnect from water (don't want it running while at home plugged in w/o water hooked up).
urs may be somewhat different. i have read some that said they have two switches inside: one for gas and one for electric.
jimh is offline   Reply With Quote
