Old 12-23-2013, 01:19 PM   #11
Hi guys
The leg is fixed, turns out it was a O ring the failed, lip pert sent out the O ring with new plug, replaced and no more leak. Glad I didn't leave it with the repair shop I had originally, it would have still be sitting there.
tromler is offline   Reply With Quote
Old 12-23-2013, 01:24 PM   #12
B47
Originally Posted by tromler View Post
Hi guys
Glad to hear this. Just curious about what this "new plug" is that your talking about.
Old 12-23-2013, 01:31 PM   #13
VinceU's Avatar
Think its the piston/foot
Old 12-23-2013, 01:34 PM   #14
B47
Not sure - be nice to see a pic.
Old 12-23-2013, 02:48 PM   #15
golfmedik's Avatar
Hi guys
Glad you got it fixed!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 12-23-2013, 03:46 PM   #16
At the top of the leg opposite side of where the hydro lines connect, there is a threaded plug ( actually two) one of the o rings was bulging out and that's where it was leaking. Lip pert sent the threaded plug and the o ring. This was the off door side hydro.
Old 12-23-2013, 03:51 PM   #17
B47
Humm - sounds like the leg is manufactured so it can be installed on either the left or right side position and the "plugs" cap off the holes that aren't used if I am understanding correctly.
Old 12-23-2013, 04:54 PM   #18
B47, yes, that's what it seems
Old 12-23-2013, 05:19 PM   #19
B47
And it took all this time and all those people to find this was the source of the leak ?
hydraulic, leak
