Old 09-16-2013, 09:05 PM   #1
Hydraulic Jacks (Landing Gear) Problem
Have been having our Sandpiper 2012 315 RET (fifth wheel) since March with really no issues until now. We tried to hook up the truck to our hitch without any luck. The landing gear switch went out (or so we thought). We have replaced the switch but still does not function properly. The jacks are down on the ground and the RV is extended all the way up. But will not retract at all. We have added more hydraulic fluid, changed the switch out, and checked the fuse. We can't move the camper to get it worked on and fixed. We have tried the manual override...same issue-will extend but will not retract. Has anyone ever had this experience??
Frustrated!!
spitre4 is offline   Reply With Quote
Old 09-17-2013, 05:41 AM   #2
Some time long ago I had the same problem with a different make of 5th wheel and had a relay that had gone bad it was about 20.00 bucks. I hope this helps it was located around the battery box up front.
ky joe is offline   Reply With Quote
Old 09-17-2013, 06:16 AM   #3
As an emergency fix only, disconnect one of the hyd lines on each ram and drain the fluid into a container.
Old 09-19-2013, 11:04 PM   #4
Ford Idaho's Avatar
Just a question.
Over extended and in a bind?
Old 01-03-2014, 07:46 PM   #5
Steve & Phyllis
SteveBingham52's Avatar
How did you get them back up? In case I have that problem.
SteveBingham52 is offline   Reply With Quote
Old 01-03-2014, 09:28 PM   #6
AquaMan's Avatar
I would be cautious in doing this! Once you release the pressure from a line, the 5er is going to drop.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
hydraulic, jacks
