Old 12-15-2017, 08:46 AM   #1
TWacker's Avatar
Inverter
I have a 2016 Sandpiper 343RSOK with a residential refrigerator. The inverter is not working. Can anyone tell me where the inverter is located?
Thank You
_______________________
1996 Chevy K2500
TWacker is offline   Reply With Quote
Old 12-15-2017, 08:22 PM   #2
Since no one else has replied, we don't have your same unit, but have seen most inverters are located in the same place. Most are located in the same compartment as the batteries.
Just curious, what is it not doing? Are you batteries fully charged?
Rich5117 is offline   Reply With Quote
Old 12-15-2017, 08:35 PM   #3
Just as confused as you
Scrapper's Avatar
Not sure I can help but if your boondocking your batteries will drain pretty quickly. If you are on shore power then check the breaker on the power pedestal and the breakers and fuses in the power distribution panel.
Do you have and know how to use a multimeter?
Richard & Jill
2011 Silverado 1500 Ext Cab Z71 4x4
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
Old 12-15-2017, 08:45 PM   #4
Scrapper's Avatar
Also check the circuit breaker on the outside near the tongue of the trailer. It is a small breaker between the battery and a junction box around the hitch area or under the front of the trailer. The positive wire comes from the battery to this breaker. There is a small reset button on the breaker.
Richard & Jill
Old 12-15-2017, 09:10 PM   #5
Scrapper's Avatar
I just looked up your 5er, look in the bay area where your batteries are for a battery disconnect and the small circuit breaker I mentioned before. Be sure the battery disconnect is not turned off. The inverter should not be very far from the battery, usually inside the battery compartment, under the bed, in the bottom of a nite-stand, or inside the bottom of a cabinet/closet.
Here is some reading to help you understand things in your RV. The ones in red will help the most.
Disclaimer: These links and articles were compiled by wmtire. He is a site team member of forestriverforums (FRF). If you give thanks, then give it to him. I had nothing to do with gathering the information, I’m just passing it along.
“I always recommend these following links to newer RV owners. It explains a RV's different electrical systems, as well as what works off of 120 volt AC vs. 12 volt DC. Not knowing your RV experience, The below is a copy and paste, and I usually recommend it to those just starting out. Some of it, you may already know, or may not be applicable to your particular RV. You will be able to filter out what pertains to your situation or not. I would suggest you read the electric threads and energy management first, and then the converter thread. This will help explain your different electrical systems of your RV, and how they operate...as well as what the converter does. The very first link will explain what operates off what system.” - wmtire
Basic electric:
Basic RV Electricity - RV Information (RV Maintenance)
https://www.rvtechmag.com/electrical/chapter3.php
RV Electric
Your very important converter:
RV Converters and Amp Draw - RV Information (RV Maintenance)
Inverters and residential refrigerators in RV's:
http://rveducation101.com/articles/rvinverters.pdf
More reading so you understand the different electrical systems of your RV.
Installing a dedicated 30 amp RV outlet at home:
How to wire a RV 30 amp outlet
Suburban water heater (if applicable to your RV):
Suburban's electric switch and much more
Suburban Water Heater Video Guides
Water Heater bypass/crossover valves:
NO (OR LUKEWARM) HOT WATER -Please read first
And the newest additions to help understand what constitutes a true full cylinder in refilling vs exchanging propane cylinders... as well as how the automatic propane changeover regulator works:
Propane Cylinders (Refilling vs Exchanging)
Propane automatic changeover regulator
Richard & Jill
Old 12-16-2017, 07:24 AM   #6
Inverter
My inverter is under my steps. From basement you pull the first wall panel down and it's right there.
My model is a 317REBH
jsalty is offline   Reply With Quote
Old 12-23-2017, 09:48 PM   #7
head gamez's Avatar
I have a '16 Piper. For some reason the wired the inverter to a battery disconnect style switch on the forward wall of the basement. It does not disconnect the battery.... it disconnects the inverter. Make sure it is on. Also, make sure the switch on the panel is on (that one is obvious).
head gamez is offline   Reply With Quote
Old 12-23-2017, 11:35 PM   #8
spaach's Avatar
You are correct. We agave a 16 343rsok with the inverter disconnect switch. After a conversation with forest river we found out the battery disconnect switch only kills the inverter. They have fixed it in the 17 model. They had the dealer wire it to turn off the whole system under warranty.
spaach is offline   Reply With Quote
Old 12-24-2017, 07:22 AM   #9
Mine is wired same way (15' 371REBH).. when my converter blew both fuses (thinking power surge) my batteries stayed charged through the inverter as it puts out some voltage.. I may even suspect this backfeed to have caused the fuses to blow on converter.. So I leave it disconnected at the battery switch until I disconnect from shore power or have a power outage. The inverter has 120v coming in to it and 12v supply and one 120v output. Odd it have 120v input .. I should research the model..
I had just figured the disconnect was there to isolate the inverter..
inverter
