Old 07-07-2016, 03:18 PM   #1
LG Ice Maker water supply in 2016 365 SAQB?
All the switches are turned on, is there a water valve? How do I know if there is a water supply to the fridge without unbolting it from the floor?
sandpiper44 is offline   Reply With Quote
Old 07-07-2016, 11:18 PM   #2
chop249's Avatar
Did your dealer not not have it making ice for you at walk through? There is another thread on here about the same thing. It mentions water shut off valves behind drawers or in cabinets.
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 4
chop249 is offline   Reply With Quote
Old 07-07-2016, 11:20 PM   #3
chop249's Avatar
Here is the other thread:
Ice maker line in your sandpiper?
Maybe you could find some useful info there. Good luck!
Bob
Old 07-12-2016, 11:39 AM   #4
There is a water valve, in our 376 BHOK, we had to remove the bottom drawer shelf and it looked liked a mushroom head, the valve can be pulled open or closed. I'll see if I still have the email from the dealer as to what it looks like. So if you have cabinets next to your fridge may want to try there
Rob_A is offline   Reply With Quote
Old 07-12-2016, 01:27 PM   #5
We solved it. The valve was already on. We needed to switch Ice Plus to On as well as switch on Ice Maker to get it going. Even then it took a while.
Old 07-12-2016, 06:28 PM   #6
head gamez's Avatar
Ice Plus should not have to be on to make ice.
2016 Sandpiper 376BHOK
2500HD Chevrolet
head gamez is offline   Reply With Quote
Old 07-12-2016, 08:52 PM   #7
AquaMan's Avatar
Ice Plus is generally just a faster cycle than normal to replenish a depleted supply.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 07-12-2016, 09:22 PM   #8
I have the LG residential fridge also and have only seen the on off switch in side freezer. Where is this ice plus you speak of? Is some sort of switch?
Tarheel fan is online now   Reply With Quote
Old 07-12-2016, 10:48 PM   #9
head gamez's Avatar
There is a button visible when you open the right had side door of the Fridge. It "accelerates" ice production.
2500HD Chevrolet
Old 07-13-2016, 12:30 AM   #10
chop249's Avatar
2500HD Chevrolet
Interesting. I will have to check that out!
Bob
365, 365 saq, water
