Old 08-24-2012, 12:36 PM   #1
Master room heating?
Hi,
Just bought our new 2013 365SAQ and love it! I have a question about the heat though. (we live in Canada)
The heat works great in the Bunk house and Main area. The issue seems to be in the master suite and bathroom. The heat register doesn't seem to be blowing any heat!
I'm thinking the ducks are blocked but wanted a second opinion and how to go about fixing this concern.
Thanks for the help
bonnieallan is offline   Reply With Quote
Old 08-24-2012, 12:53 PM   #2
Originally Posted by bonnieallan View Post
Hi,
Thanks for the help
You might want to close the other ducts down a little and look for kinks in the ducting on the others.
Old 08-24-2012, 01:29 PM   #3
Cflmom's Avatar
I don't think these registers close. Is there another way to do it? Or do they need to replace the registers with ones that do close? That's what we had to do in ours to get heat to the master bedroom.
Cflmom is offline   Reply With Quote
Old 08-24-2012, 01:29 PM   #4
TURBS's Avatar
Hi,
Thanks for the help
If your unit is a 5th wheel Does your unit have a heated basement?
If so close that off and install closeable registers in bunk house and kitchen/living area.
Had the same issue with my sabre.
Old 08-24-2012, 01:30 PM   #5
TURBS's Avatar
Yes you need to purchased closeable ones.
Old 08-24-2012, 03:44 PM   #6
We replaced the ones in our living area with the closable ones from Lowes. Just take one with you to make sure you get one the fits.
Old 08-24-2012, 04:48 PM   #7
As a temp/test, cover the other registers with duct tape, and make sure you get airflow to the master bedroom. If not, then you have other problems that need fixing, collapsed duct, disconnected duct, could be a number of things. If there are no problems in the duct work then the problem is, they use one size duct for the whole trailer. The farther away from the furnace you are, the less air flow you have, unlike a house where the duct work is sized down. You will have to limit it somewhere to force it somewhere else.
Could just get a small ceramic heater to supplement.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-24-2012, 05:11 PM   #8
amxpress's Avatar
I installed these on my previous fiver. I closed them when I wanted to direct more heat to the front. We also used a small ceramic heater which worked well in the cold months. Great when taking a shower or getting dressed in the morning. Click here: 4 X 10 Brown Floor Register - RVWholesalers.com RV Parts and Accessories
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 08-25-2012, 10:01 AM   #9
Thanks for all your replies, will try all of them. We did figure out how to switch the thermastat to "auto" which stops the airconditioner working at the same time as the heat!!!! So thats great Now to get the heat to flow to the front of the trailer. Thanks again everyone
