Old 07-15-2013, 09:41 PM   #1
Mounting a 32 inch tv in bunkroom
Wondering if anyone has mounted a 32 inch flatscreen in their 365saq bunk room? It appears its solid plywood but I'm worried the seesaw effect while traveling at times may rip it right out of the wood?So if anyone has done this and has traveled with it let me know how its working out. Thanks
Rtazz17 is offline   Reply With Quote
Old 07-16-2013, 07:35 AM   #2
5erDriver's Avatar
Hi. Yes I have mounted a 32" in there with no problems. It is plywood and from memory I think it 5/8. If you unscrew the cable connection cover plate you can see. I mounted a fixed position mount. I used nice thick 1 1/4" wood screws predrilled and just added washers to make up what the heads needed so they wouldn't slip through the slots in the mount. If you like you could include a lock washer but once the wood screws bite and are tightened up they are not going anywhere. No problems with traveling. Have done many hundreds of miles since.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 07-16-2013, 07:38 AM   #3
Ok thanks alot.. It feels solid..
