Old 06-24-2017, 10:14 AM   #1
muddyrode's Avatar
Need help with inverter
Can anyone tell me where the inverter is located on a 2016 35 ROK
I can net get it to work.
Is there an switch that needs to turn it on?
muddyrode is offline   Reply With Quote
Old 06-24-2017, 08:41 PM   #2
I have a 381RBOK. My inverter is in the "basement". In the cargo area, the side away denim the nose is attached with a few wood screws. Just take those out and it comes right out. Inverter and a lot of other guts items are in there. If yours has a disconnect switch, mine is in the cargo area, if it's off your inverter won't work if it's wired like mine. The disconnect switch is on the nose side of the cargo area on my rig.
jetsg4 is offline   Reply With Quote
Old 06-25-2017, 07:49 AM   #3
muddyrode's Avatar
Thanks jetsg4
and yes mine does have the dissconnect but still will not work
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
Old 06-25-2017, 09:07 AM   #4
from your question I am assuming an answer. if you cannot find or reach the inverter it would make sense that there is a switch that you can reach that needs to turned on. the fact that you are asking if you have one implies that you haven't turned it on. i'm sorry, I don't know the details of your model so I cannot tell you where it is. look for a small on/off switch. it probably has an indicator light in it that comes on so you know when the inverter is on. it might have a brand name on it. ours says 'prowatt' but other brands may have different markings.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 06-25-2017, 03:02 PM   #5
Havasu Bill's Avatar
My inverter has a GFCI that will trip for what appears to be no reason.
I replaced the GFCI and had the same problem so ended up installing a regular receptacle in place of them. No issues since then.
Bill
2016 Forest River 3250 Cardinal
2016 RAM 2500 Longhorn
Previously: 36' Country Coach
Havasu Bill is offline   Reply With Quote
Old 06-26-2017, 09:10 AM   #6
muddyrode's Avatar
found the problem bad connection on the inverted
thanks to all
inverter
