02-10-2014, 01:59 PM
#41
Originally Posted by jevanb
sure looks nice, what is the pin weight of they monster?? thought it would not push the truck rear that far down.. should of looked at the first post, that 2500HD looks the same as mine with the trailer attached (level)
When I weighed it empty it the pin was 2,140 and I have not been back to the scales since I have put all my junk into it. I do plan on hitting the scales when I pick it up.
It dropped the rear of the truck 1.25" and it does appear to be sagging in the rear. From what I have seen the F450's all sit pretty level when they are unloaded and this is the result of it. I will tow it a few more times to see if I want to put airbags on it, but after pulling it today it's not real high on my list of things to do. The pic of the camper behind the 2500 is with airbags and inflated to either 45 or 50lbs of air in them so that did assist in it looking more level. This camper dropped the 2500 a little over 2" when it was hooked with no air in the bags.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
02-10-2014, 08:59 PM
#42
And I thought I was happy with my '13 F350 until HE comes along with a 6.7L F450!!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
02-11-2014, 11:31 AM
#43
2015 Chevy 3500HD
02-11-2014, 07:39 PM
#44
Testify! What a show off! lol.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
02-16-2014, 02:35 PM
#45
Ok I have a 2013 6.7 F350 SRW with a 14 ROK ordered. It has a pin weight slightly north of 2400lbs. Are you guys saying I should put air bags on? If so what do they cost and can they be installed by me, I'm pretty mech inclined, or have them installed? I've been told the 350 could pull two of these things but that was dealer talk!
02-16-2014, 04:54 PM
#46
I like the addition of airbags due to taking some of the jolt out of the interstates, leveling the truck so the headlights are aimed correctly at night and with having on onboard system, I have air anywhere the truck is. As far as you needing them, that is everyone's preference. I like my truck and trailer to sit perfectly level, so yes I needed them and I have a dually. It is 4WD by the way, 2WD may not need them to sit level. My pin weight is around 3100 pounds on my truck. You can install them yourself in about 3-4 hours with no problem. They reduce suspension fatigue on the trucks as well. I won't ever tow heavy again without them. Either Firestone or Airlift have very good bags. I just have Firestone because they were on sale at the time. Also. keep in mind, you pin weight will go up when you load it. Don't just go by the manufacturers numbers!
Monty
03-06-2014, 11:39 AM
#47
Update time!
Yesterday I made it over to my dealer and picked up the camper with its shiny new wheels, tires, and axles. While it was there they adjusted the bedroom slide so it now goes in and out without sounding like you stepped on a cats tail They also fixed some wood trim in the bunk area for me. One bonus is that they let me keep my old (good) wheels and tires that I had purchased so I can throw those guys on Craigslist to make some $$ towards a decent set of new tires
Here is a pic of the new wheels and tires. Wheels are Sumec wheels, they have bolt in valve stems and are good to 200PSI. The tires are Westlake Super ST's in load range E, they will have to do for now until I can throw some better tires at it. I checked a picture I took yesterday and luckily I was able to make out the DOT date code. The tire I got a closeup pic of shows a date of 3813 (mid to late September) and I'm ok with that.
They did send new stickers and the only thing I don't like is the dealer just put them on top of the other ones and it makes it look weird.
You can see in that picture that the cargo weight has increased drastically. Before the yellow sticker said cargo should not exceed 1219lbs, now I'm up to 2659lbs...much better. The GVWR went from 14,060 to 15,500 as well and that was expected.
2015 Chevy 3500HD
03-06-2014, 08:41 PM
#48
Glad you got everything squared away...hopefully she will serve you well and you guys can enjoy her as much as we have ours. And now she is properly fitted with the correct equipment! Good luck and send us pics of some camping trips!
Monty
03-06-2014, 08:53 PM
#49
You will want air bags!! They make a huge difference!! I have a 2011 f 250 with A 365 saq. I have the Firestone airbags with an inboard compressor.
03-07-2014, 11:38 AM
#50
Thanks Monty, we have several trips coming up and will get some miles under it. We are excited to get it out and use it finally.
Chiro - I am still pondering on the air bags. I think the next couple trips will let me know if I need them or not.
2015 Chevy 3500HD
03-07-2014, 02:50 PM
#51
I love my airbags and onboard air system. They help keep the rig level, although it didn't need much help in that regard. The headlights are like driving normally, but I love having air to air up floats, tires etc wherever the truck is. I also like the fact that I can adjust on the fly and take some of the 'jolt' out of some of the interstate expansion joints.
Monty
03-07-2014, 05:36 PM
#52
Hey guys
What does everyone have for pin boxes? I have a SRW F350 Long Bed with no airbags. I have a 2013 365saq. I find the ride very nice towing. I do have the Trail Air Rotoflex pin box which was installed at the factory. Although not a higher dollar air bag box it does the job well. My good friend, and very experienced 5th wheel tower, rode with me on the 450 mile round trip to my dealer to get my axles done recently and commented on how smooth the tow was and how you'd barely know the camper was back there. He has a 3500 single with Firestone bags installed for his 40' 5er with a standard pin box. I have no doubt the bags would make things even better again but just curious about the pin boxes.
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
03-07-2014, 05:41 PM
#53
I have the standard Lippert pin box on mine.
03-07-2014, 10:03 PM
#54
I have the Trail Air Rotoflex on mine as well and I think it rides pretty good. Not sure if its the pinbox or not, but I'm sure it can't hurt.
2015 Chevy 3500HD
03-09-2014, 05:11 AM
#55
I'm not sure if it's a Ford thing or not, but I really didn't care for the air bags on my '11 2500 Chevy. I thought the ride was bouncy and anything more than 35 pounds would raise it and make the ride harsh. They did help some on the hard bounce of a bridge approach, but under normal driving conditions I didn't care for them. I definitely don't need them on the 3500. Neither truck was squatted in the rear when hooked up, both dropped less than 2".
