Old 09-29-2014, 06:09 PM   #21
Be sure to drain the (W/H) 1st,then the low point drains! If you do it in reverse the flow carries (Crud) from the W/H downstream in the lines! Youroo!!
Old 09-29-2014, 06:11 PM   #22
Kaadk's Avatar
And don't forget to turn off the Electric before you drain!
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
fresh water, water
