08-03-2012, 08:17 PM
Painting skylight to reduce heat
I had really had it with the heat that the skylight lets in in our 365. I dealt with it in our 355 too, but the trip a month ago to Myrtle Beach made me furious with the heat in the bathroom. I've seen several mods to block out the light like putting a cover on the inside of the skylight, but it still let in a lot of heat. So I bought some Krylon Fusion Gloss White Paint and cleaned the skylight with Spray Nine and Dawn, taped off the roof and painted it. Several other posts had said that it blacked out the light completely, but I tested this paint on plexiglass first and had good results. I could not believe the heat reduction in the bathroom and camper after doing this. It was amazing. This method still lets in a lot of light, with a very small amount of heat. Here is a pic after it was done.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
08-04-2012, 11:09 AM
Interesting. I bet it stopped most of the squirrels from "peeping in", too! Job, glad someone else did it before I tried it. FL seems to have the same heat problem.
Brenda and John
Master Blaster of the Navy
08-04-2012, 12:17 PM
After this weeks trip in the Windjammer, I "remembered" I wanted to do something about the skylight. Thanks for the suggestion.
JR
2008 Toy Tundra DC 5.7L Bagged w/LTs
Hensley Arrow
2012 Windjammer 3001W, Atriumed
08-04-2012, 01:34 PM
Would be curious on how it holds up.
Good job .
08-04-2012, 02:01 PM
golfmedik- nice job! I think I have to seriously consider that mod.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
08-04-2012, 02:59 PM
Tempered safety glass
I used tempered GREY tinted safety glass. I removed the thin clear plastic from the overhead in the shower (it will snap right off from the frame). Silicone the safety glass to the white frame. Removes the UV rays, heat and still looks like I can still see the squirrels.
Used the same glass on the entry doors, but with a added tint to prevent anyone from seeing in. Now I can see out but no see in.
cost for each piece of glass was about $14.00.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
08-04-2012, 03:44 PM
Good job .
I am too, however, it is an easy fix. Lightly scuff and repaint! Wanted to do this on our other one, just never took the time to do it. So far, I am really impressed with the heat reduction.
08-19-2012, 05:35 AM
This may be to late to post but I used window tint to cover it. It did wrinkle around the edge some but it looked ok and you can remove it if you want later.
