09-26-2013, 10:27 AM
#41
daydreaming about camping
Originally Posted by melissajean0
Hey how do I get my pics under my posts like you have?
go to "user CP", top navigation bar, second option from the left.
Then go to edit signature.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
09-26-2013, 10:30 AM
#42
Originally Posted by Brother Les
Now you are learning what we are talking about. The buttons on the wall (Fresh water/ gray/black/ batt) that tells you a lot. If you had really good lights before, then the batt reading would not (imo) have been down to 1/3 when he looked at it if should have been higher. I think that you are running on the converter alone. Can you tell which slot is for the battery. there may be a slot that has a fuse in it that you are not using. I have a couple that I don't use, but I also have an extra fuse stuck in one side and 'left open' in order for me to have one at hand and not have to look (ask the wife) for where they are.
lol right. Ask first look later.
I ask my bf all of the time, "what do I have xray vision? how am I supposed to know where EVERYTHING is???" hahahha
No, I don't know which is for the battery, none of those empty ones are labeled.
09-26-2013, 10:32 AM
#43
hmmmm....well...I edited it, but it's not showing up on my posts. allllllrighty then lol
09-26-2013, 10:33 AM
#44
You think so?? My bf's dad doesn't have a lariat, but he's got a F350 Dually and it gets like 23 mpg. I know there's a thing you can put on it to boost your mileage, but it throws out black smoke when you floor it...which I do a lot. haha!!!
He has some type of 'Chip or Tuner' in it. I have a 'SuperChip' and can get 'around' 24-27mpg.... when not pulling and how much smoke I put out. How they work is by changing the RPMs and shift points of the transmission. The 'set-up' will have one mode for pulling and one for not. When I am pulling I get 14-16mph.
Brother Les
09-26-2013, 10:34 AM
#45
Bf says he doesn't care what ours gets, he's still not getting a damn dodge. He wants to get that chip put in, but idk if he should with my lead foot.
09-26-2013, 10:37 AM
#46
The chips/tuner not just help the mpg they also help with POWER....
Find your truck year and talk to the guys (your BF) in this forum and they will recommend what may be best for your truck.
Ford Truck Enthusiasts Forums - Ford truck and SUV owners and enthusiasts Community And Information Source.
Brother Les
09-26-2013, 10:38 AM
#47
Oh hey thanks! I'll definitely check that out.
09-26-2013, 10:48 AM
#48
Did you click "save signature" lower down?
Brother Les
09-26-2013, 01:08 PM
#49
I did....still doesn't work :/ boo hoo I feel left out.
09-26-2013, 01:28 PM
#50
lemme seeeeeee....does it work now?
09-26-2013, 01:29 PM
#51
that'd be a no lol
09-26-2013, 01:32 PM
#52
Originally Posted by BarryD0706
Turbs is of the opinion that a WFCO Converter should NOT be operated without a battery. He knows a lot about converters. (I'd trust Herk if he says it's ok.)
I agree with Les's test for AC power. (He would have been more likely to turn the breaker off in the power pole box outside I think.)
As I said above, I'm not so sure that it's ok to turn it back on without the battery/fuse on there. At the least, make sure all of the wires outside where the fuse used to be are taped up.
I still think the right approach is to replace the missing fuse.
True barry! Although I suppose you can run a wfco converter without a battery for an emergency it is "HIGHLY" recommended NOT to.
After talking to a tech at wfco and several emails he said smoke will release from the unit if there's not a battery buffer in the system.
It will overheat as the fan/ fans will not keep up with the heat.
Same goes for a "bad" battery.
New Progressive dynamics on the other hand can be run without a battery.
Turbs
09-26-2013, 01:36 PM
#53
09-26-2013, 02:21 PM
#54
Totally off-topic, but for future reference. I was checking your profile and see we are possible neighbors. The WM in my name is the abbreviation for West Monroe.
2011 Flagstaff 831 RLBSS
