Old 09-26-2013, 01:29 PM   #51
melissajean0's Avatar
that'd be a no lol
melissajean0 is offline   Reply With Quote
Old 09-26-2013, 01:32 PM   #52
TURBS's Avatar
Originally Posted by BarryD0706 View Post
Turbs is of the opinion that a WFCO Converter should NOT be operated without a battery. He knows a lot about converters. (I'd trust Herk if he says it's ok.)
I agree with Les's test for AC power. (He would have been more likely to turn the breaker off in the power pole box outside I think.)
As I said above, I'm not so sure that it's ok to turn it back on without the battery/fuse on there. At the least, make sure all of the wires outside where the fuse used to be are taped up.
I still think the right approach is to replace the missing fuse.
True barry! Although I suppose you can run a wfco converter without a battery for an emergency it is "HIGHLY" recommended NOT to.
After talking to a tech at wfco and several emails he said smoke will release from the unit if there's not a battery buffer in the system.
It will overheat as the fan/ fans will not keep up with the heat.
Same goes for a "bad" battery.
New Progressive dynamics on the other hand can be run without a battery.
Turbs
Old 09-26-2013, 01:36 PM   #53
daydreaming about camping
jeeplj8's Avatar
see post 25 for instructions:
Forums 101 - posting, accounts, basics
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 09-26-2013, 02:21 PM   #54
wmtire's Avatar
Totally off-topic, but for future reference. I was checking your profile and see we are possible neighbors. The WM in my name is the abbreviation for West Monroe.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
battery, fuse
