Pics below. I misspoke on the placement. I have it at the very front, but we use a wire rack over it so it doesn't interfere with storage. I forgot that I ended up that way instead of pushing it to the back.
The cable coming into the right of the EMS is the original cable that went into the panel. I disconnected it and ran it through the hole and into the EMS.
The cable coming out of the left is a 6' long cable I bought from Lowes. It goes through the second hole and back to the panel. I had grommets in the holes, but looks like they have worked loose. I guess because I never actually attached the EMS and it has shifted slightly. Need to do that and put the grommets back.
The picture below shows the setup and its proximity to the panel.
I decided to not mount it behind the panel just in case it ever cause any problems. I could easily access it to troubleshoot. Getting in behind that panel is a chore!
2016 Sandpiper 376BHOK
2500HD Chevrolet
