Old 10-10-2016, 08:30 PM   #1
Rear end floor rot
We just purchased a 2008 316BHT and had it inspected first. Our unit has a rear bedroom and 1/2 bath. The floor is soft in two places.
The RV shop says they will have to remove the fiberglass cap on the rear to access the damaged areas.
Has anyone had any experience with this?
Bruce
2006 Sandpiper 316BHT
2002 Ford F-350 Diesel
BruceAndGlo is offline   Reply With Quote
Old 10-10-2016, 08:43 PM   #2
crunchman12001's Avatar
Did you have it inspected before or after you bought it. This is gonna be huge dollars to repair. $$$$. If possible, if the seller did not disclose, I would run as fast as you can.
2015 F-250 FX4
crunchman12001 is online now   Reply With Quote
Old 10-11-2016, 05:58 AM   #3
Yes we did find it in an inspection. The shop said it would take around $1,500 to fix so the seller reduced the price to cover the repairs.
Wondering how hard it will be to do the repairs?
2008 Sandpiper 316BHT
Old 10-11-2016, 07:27 PM   #4
Hi,
$1500 sounds extremely inexpensive to remove the rear fiberglass cap, remove furniture and cabinets, tear up flooring and subfloor. Remove and replace insulation (kill black mold if needed) install new subfloor and flooring, reinstall all the rest of the inside and put the rear cap back in place? I would have guess $5k to $6k.
Still wondering why they have to remove rear cap for a soft floor? Where are the soft spots?
2015 F-250 FX4
Old 10-11-2016, 11:30 PM   #5
Hi, there are two soft spots. My unit has a rear toilet and soft spot #1 is along the outer wall about 5" sq. The tech could not be sure where the leak was coming in but he suspects it might have been the drivers side tail light and leak #2 is under the rear window. One can see a water trail from the window to the floor.
I guess the walls are hanging and attached to the floor from the end. I'm assuming that is why the cap needs to be pulled to properly rebuild and attach the flooring
Bruce
Old 10-11-2016, 11:32 PM   #6
There is no furniture along the rear wall in this design. It's all on the forward wall.
Old 10-12-2016, 04:15 AM   #7
Sounds like the damage is small and contained. Sure can't beat the price for that much labor. When are they supposed to start working on it?
Keep us posted.
Good luck
2015 F-250 FX4
Old 10-12-2016, 04:57 AM   #8
Oaklevel's Avatar
Our dealer does it often a $1500 dollar cost is probably in line here. (But our dealer's labor rate is $60 an hour some are double that) ........................But keep in mind that the repair shop may find more issues when opened up and there be a higher cost the job is done. I would if possible get the owner to get the work done first.... esp if it is the dealers and stop by to check on the progress.
Good Luck !!!!! Should be plenty of other used ones out there.....
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 10-15-2016, 09:25 AM   #9
Where is your dealer located? That's a better hourly rate than I have.
Old 10-16-2016, 07:29 PM   #10
kittlecat's Avatar
Did you purchase the coach from an individual or an RV dealer? My concern is how significant the water damage and possible black mold might be. My TT was totaled earlier this year due to water damage and black mold in the floor of the TT from an unknown leak.
Kittlecat
"Integrity simply means not violating one's own identity." Erich Fromm
"You have to understand who you are to know who you are not." Anonymous
"Know yourself, know your world. Change it." Anonymous
kittlecat is offline   Reply With Quote
