Old 08-01-2016, 06:56 AM   #11
DDC
DDC's Avatar
Originally Posted by mbbutler View Post
They make a tray with drain sized perfectly for the Splendide units. I just drilled a hole in closet floor and ran hose into front storage area and down one of the stabilizer Jack holes.
I wondered about that when I got the new Silverback with factory installed washer/ dryer, where did you get the tray from?
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 08-01-2016, 07:08 AM   #12
mbbutler's Avatar
Amazon. It is a 24" tray.
"Westland drain-a-way"
2016 Cedar Creek Silverback 33IK
2008 Ford F-250 Crew Cab 4x4
mbbutler is offline   Reply With Quote
Old 08-01-2016, 08:56 AM   #13
denali15's Avatar
A pan might be good prevention but your biggest chance of a leak/flood using a washer in a RV is your grey tank filling up.
If this happens the water will overflow out of your lowest point which will most likely be your shower.
Best prevention is to keep an eye on levels or even better keep your grey water open when doing laundry.
Saw someone that flooded his RV last week; his wife started a load of laundry and didn't tell him, they went for a walk and when they came back water was coming out of the bottom of the fifth wheel......
denali15 is offline   Reply With Quote
