Old 07-30-2016, 08:49 PM   #1
Remove carpet when installing washer / dryer combo?
We are installing a washer dryer combo in our Samdpiper 5th wheel. It will be in the closet. Has anyone removed the carpet under the washer when installing or just on the carpeted floor of closet? Any feedback would be appreciated. Thanks
Sent from my SM-G900V using Tapatalk
acyale is offline   Reply With Quote
Old 07-30-2016, 10:33 PM   #2
I installed mine on the carpet
ksignoles is offline   Reply With Quote
Old 07-31-2016, 09:58 AM   #3
denali15's Avatar
Same. I installed mine on the carpet...
denali15 is offline   Reply With Quote
Old 07-31-2016, 10:02 AM   #4
Thanks, we did the same.
Old 07-31-2016, 03:45 PM   #5
RetiredRVer
Being a retired plumber, I would remove the carpet, and place some type of drip pan under the washer.....I have seen far too many washer leaks that destroyed flooring under them. (In residential uses.) In a moving, shaking mobile RV, probably even more important. just my opinion.
Joe & Sandy
Mentor, Ohio
2015 Chevy 2500HD Crew Cab 4X4 6.0 "Gasser"
2014 Wildwood Heritage Glen 282RK TT
2018 "FROG!" To Alaska
checkmate99 is offline   Reply With Quote
Old 07-31-2016, 07:01 PM   #6
I removed carpet installed a drain pan and installed the proper hold downs on the front legs. No movement and any leaks drain outside.
John and Julie Parish
Lansdowne, Ontario, Canada
2015 Ford F250 Diesel
2009 Cedar Creek 34RLSA
Retired but still working sometimes to pay for toys
jdp105 is offline   Reply With Quote
Old 08-01-2016, 06:33 AM   #7
Leaks
This and previous ost X2
pdqparalegal1 is offline   Reply With Quote
Old 08-01-2016, 06:46 AM   #8
ilmor's Avatar
This is what I would do as well.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-01-2016, 07:08 AM   #9
Remove carpet! Youroo!!
youroo is online now   Reply With Quote
Old 08-01-2016, 07:27 AM   #10
mbbutler's Avatar
They make a tray with drain sized perfectly for the Splendide units. I just drilled a hole in closet floor and ran hose into front storage area and down one of the stabilizer Jack holes.
mbbutler is offline   Reply With Quote
