Old 09-23-2013, 03:17 PM   #1
Roof
We have a 2001 Sandpiper that we purchased this summer. On the edges of the roof it is cracking, They are small and the RV Dealership told us to us to use self leveling sealant and brush it out. Just wondering if anyone has any other suggestions?
julie47273 is offline   Reply With Quote
Old 09-23-2013, 05:32 PM   #2
I would need to see a picture but eternabond tape is a better solution if its practical to use in your application..
Rtazz17 is offline   Reply With Quote
Old 09-23-2013, 05:51 PM   #3
Batts-toy's Avatar
Search this forum or you tube eternabond there are videos showing how to apply it, I understand it is really good when used.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 09-23-2013, 06:37 PM   #4
Roof
ID:	40169   Click image for larger version
Old 09-23-2013, 07:12 PM   #5
Def alot of cracking there. I would prolly get a roll of 1 or 2 inch eternabond tape and go the length with it. Be careful with it. Once its on its on and isnt coming off.. Just prep it right and it should work better then new.
Old 09-23-2013, 07:24 PM   #6
Iwannacamp's Avatar
I ordered and used some eternabond tape on e-bay. I patched the radio antenna hole...tree limbs. Seems to work great...time will tell
3" x 50 ft on eBay I think it was $50
internal antenna $4.15 eBay no freight
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-23-2013, 07:26 PM   #7
Iwannacamp's Avatar
PS: I saw on here about the wine guard tv antenna rubbing a hole...mmm. It was close. Put some tape under contact areas. ✔️
2017 Puma 297RLSS
Old 09-30-2013, 07:38 PM   #8
hrlyguy2's Avatar
I had a older camper with the same issue.I did use the tape and worked great.But I used 3" wide tape.Some say use a primer.I didn't
Just used dawn dish soap to clean it. rinse it off good let it dry.Then I used rubbing alcohol after for good adhere.Put the tape on slowly peeling away the plastic as you go.Get your self a small roller to put good pressure through out.
For a piece of mind I got some clear Rv chaulk and did all the ends .
Worked great for me
Just had a tiny issue with a tree .Did the same thing on a newer trailer.
Good luck
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
roo, roof
