Old 11-03-2011, 12:38 PM   #1
bek1981's Avatar
sandpiper 35 loft winterizing question
I have a winterizing valve that you turn and a hot water bypass valve, but when I turn the winterizing valve, I don't know where to put the af to pump it threw the lines, can anybody help
bek1981 is offline   Reply With Quote
Old 11-03-2011, 12:39 PM   #2
TURBS's Avatar
should or could be out by your frsh water fill and or city hook up ?
or theres a hose laying by your water pump .
Old 11-03-2011, 12:43 PM   #3
bek1981's Avatar
I took the side off to see the pump but the hose goes to the the winterizing valve.
Old 11-03-2011, 01:36 PM   #4
bek1981's Avatar
Old 11-05-2011, 11:27 AM   #5
Turn your CITY valve to CITY, WINTERIZING valve to WINTERIZING, the pump will pull from your CITY hookup. Put a short piece of hose to CITY hookup and the other end into a bottle of antifreeze, turn on pump.
P.S. Be sure to bypass water heater.
___________________________
2010 300RG Sandpiper 5er
t-dsandpiper300rg is offline   Reply With Quote
