Even if the back flow valve were installed backwards, it should not leak. A back flow valve is a fancy name for a check valve. It only lets flow travel one direction. If the flow tries to reverse, it closes and prevents this. Regardless of direction, it should not leak. Only way to find this is hook up the hose, ease the water on, then go inside with a flashlight and see what is leaking. Good luck.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
