Old 08-05-2016, 01:13 PM   #1
ccsvolsfan's Avatar
Sandpiper 360PDEK A/C
I went through my complete a/c system and retaped every joint including the ceiling air registers. Also plugged up the end of run duct in ceiling. Using an anemometer before and after, I gained .8mph at the terminal air registers. It's 100F here and the air coming out of register is 66F.
Previously I pulled off tops of units and resealed the openings where wiring went thru an the installer leftist sized holes allowing air to go into attic area.
A little work, big rewards.
ccsvolsfan is offline   Reply With Quote
Old 08-06-2016, 09:47 PM   #2
Did the same to our PDEK in June. Made a huge difference. I can get the temp down to 76 in the direct sun at 96 outside with 70+ percent humidity.
Sierra360PDEK is offline   Reply With Quote
Old 08-09-2016, 12:15 PM   #3
Same here. My ducts wasnt connected to the vents or connected to the ac units. I taped all the joints and actually have too much air pressure in the bedroom and bathroom.
brad2388 is offline   Reply With Quote
sandpiper
