Old 02-11-2018, 12:08 AM   #21
Hello all I am an RV technician and the response from the fellow Rv folks are correct. the switch inside the Rv is for L.P ignition and the switch on the outside of the Rv is for 110 volt .l.p will heat up your tank faster 110v will act like a home water heater and will not recover as fast .
djkidd is offline   Reply With Quote
Old 02-12-2018, 05:22 PM   #22
rracer5's Avatar
Thanks all. We got it. No better place when you have questions than right here on FRF.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-12-2018, 06:16 PM   #23
While we're on the subject of WH. Can I replace my 6 gal with something larger? I have room inside as it is under my kitchen sink. It's the trailer side opening I wondering about. Tthe trailer is 1400 miles away. It is a Suburban.
Old 02-12-2018, 06:51 PM   #24
I would recommend you take it in to a shop near you to see if it can be done . So I can't tell you for certain if it can be done
sandpiper
