Old 07-15-2016, 07:23 PM   #21
But the flow of cold air through a light fixture is odd.. no?
jsalty is offline   Reply With Quote
Old 07-15-2016, 08:00 PM   #22
You can probably climb on top and pull the cover off the unit.
If it's 80 degrees, it shouldn't take long for the system to defrost.
I'm just passing on what worked for me.
GrumpyOldGoat is offline   Reply With Quote
Old 07-15-2016, 09:41 PM   #23
Old 07-16-2016, 11:36 AM   #24
Pull your interior cover off and look at the area where the air moves into the ductwork. Mine a 1" hole in the metal tape and the air was going into the ceiling . I repaired that and then removed all vents and retaped them as well, most of the tape was loose and either blocking air flow or allowing it to escape I to the ceiling. The last thing I did was place a towel just past the last vent forcing the air out the vent instead of wherever it went.
Sierra360PDEK is online now   Reply With Quote
Old 07-16-2016, 10:17 PM   #25
Thank you for the idea. I pulled the cover off zone 1 (living room) and it was a mess.. tape blocking duct back to rear vents , the forward duct was missing tape over 80% of it with gaps I could put my hand through..
I fixed all that mess then I went to each vent, all but one had large openings to the ceiling. Fixed these areas.. the zone 2 (master bedroom) AC had only a small 1"x1" gap... repaired that as well. I turned the living room unit on and could feel a 90% increase in flow out if the rear most vent.. even had air coming out of bedroom vents too...
Only thing is, somewhere cold air is getting into ceiling as I could still feel it coming from a bathroom (above toilet) light when cover is removed. Must be where two ducts are joining and will likely stay that way..
Old 07-17-2016, 09:47 AM   #26
Great to here it worked. It's sad we have to go through all of this after spending $45000-$50000 on a new rig.
Camp on and stay cool.
Old 07-19-2016, 03:14 PM   #27
381 RBOK Leaking Ducts
I went on my roof (2016 381 RBOK) and saw a wet spot near the rear skylight for the bunk room. It was condensation and the roof was cool there. I went up there several mornings and it was always the same place. The dealer had to pull the roof panel down from the bunk room and found the AC ducts were separated in that area. It was blowing air directly to the underside of the roof.
I also had to have extra return ducts installed. I just picked it up this morning and hopefully it cools adequately now. So far, the cooling of this trailer has been far below adequate.
jetsg4 is offline   Reply With Quote
Old 07-23-2016, 06:42 PM   #28
BDavis's Avatar
2016 365SAQB that had a few issues that I fixed myself. Leaky AC duct at the unit was an issue and even though the dealer fixed it I wasn't real happy with the finished product and taped it up myself. Some of the AC vents had poor taping as well. We have been 100 degrees in direct sunlight and seem to hover around 78 with both units running. Cools off fine at night. Thinking of adding a 3rd unit to the rear bunkhouse area. Yes...gonna take some engineering.
Otherwise minor issues that I fixed and fixed correctly. I am amazed though that there are not stricter quality control measures on these things.
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 07-23-2016, 10:22 PM   #29
Sounds about the same as mine.. I am now dealing with the living room unit not performing as good as the bedroom units (air is not as cold). I may just replace with 15,000 btu unit and be done with it... it's under warranty but that takes months to get the dealer to respond and repair. I don't have that kind of time. It's been high 90s here and I struggle to get below 80 in living area until after dark.. 79 right now.
There is no quality control.
Before I purchase another one I will be looking at it in more detail and performing some performance tests prior to accepting delivery...
Old 07-24-2016, 10:43 AM   #30
I posted pics of the vent issues one time. My 371Rebh had large gaps in the return section, which made me want to inspect further, so off came the vents covers and all of them needed some attention. Retapeing corrected it. I still check em all periodically when cleaing or changing filters.
Mikele is offline   Reply With Quote
sandpiper
