Old 05-24-2011, 07:29 PM   #11
TV Problems
The white cable is cable tv, the gray cable is satellite. On my Sandpiper there are two satellite hook ups. The bottom satellite hookup is the one for the living area. I did get the satellite to work.
However, like you, I can get the regular tv antennae to receive in the bedroom but can't get it to receive either regular or HD signal in the living area.
pepajohn is offline   Reply With Quote
Old 05-24-2011, 08:29 PM   #12
Herk7769's Avatar
Originally Posted by flo99 View Post
the confusing thing to me is that there are only 2 cables coming from the wall in the main tv area...so let's say that one of the cables is from the antena and the other is from One of the 2 inputs from the rear of the RV....my question is being that there are 2 inputs in the back shouldn't there be 3 cables in total? 1-from the antena, 1-from the rear input that says sattelite and 1-from the input in the rear that says park cable?? that to me is how many "inputs" i see.....am i wrong?
Sigh, no. (er, yes; you are wrong)
The park cable from outside goes to the amp switcher.
The roof antenna cable goes to the amp switcher.
The output from the amp switcher goes to a two way splitter and one cable goes to the bedroom TV and one goes to the Living room TV or if not a wallplate jack (TV1) and cable run to another wall plate jack (TV2).
The SAT cable from outside just goes to a splitter and one leg goes to the SAT wall plate and the other leg goes to the bedroom.
SAT is ALWAYS a home run with nothing but splitters in the line.
The Park cable and roof antenna share the output of the amp switcher.
HAM CALLSIGN - KC3FFW
Old 05-24-2011, 08:48 PM   #13
Herk7769's Avatar
Additionally:
Look at figure 4 on the attached PDF.
Remove the amp wall plate and look at where there are 3 wires going out of the bottom.
The one on the right as you look at it is the one that goes to a splitter that feeds your TV or goes directly to the LR depending on how the bedroom TV hoks up (wall plate itself or a cable).
The SAT cable is home run and avoids the switch entirely. It can be split also (usually in the wall).
Old 05-24-2011, 09:06 PM   #14
Herk7769's Avatar
This could complicate things. If there is indeed TWO SAT connections on the outside cover (photo of cover please) then you have two home runs one to the front and one to the back. There should be a THIRD connection there as well (Park Cable that goes just to the switch).
Here are photos of my outside box and the wall plates inside.
Name:	913th 3rd Annual Picnic and Camper photos 041.jpg
ID:	5976   Click image for larger version
Name:	913th 3rd Annual Picnic and Camper photos 040.jpg
ID:	5977   Click image for larger version
Name:	Camper Slide Braces 007.jpg
Old 01-06-2016, 12:23 PM   #15
Wink Coax Wiring Flagstaff 8528 RLIKWS
Was not sure where to post this as I have seen numerous comments about coax cables and wiring. Attached is a simple diagram of how my 2015 Flagstaff Super Lite 8528 RLIKWS is wired for SAT/ANT and Aux. Hope this provides some resolve for anyone interested. As you can see there is a SAT/ANT In and an Aux In. The Aux is a single line (black) that goes to the main TV area. The SAT/ANT is a gray cable that goes to a three-way splitter and feeds the Main TV, Bedroom TV and Outside TV (pass thru). The single plate in the main area marked as Satellite to bedroom is actually a connection to the bedroom that is a dedicated line and can be used for anything you want to connect it to from the main area for use in the bedroom.
Ron & Sue Snavely
2015 Flagstaff Ultra Lite 8528 RLIKWS
2014 Chevy Silverado
Recently retired and 2nd year full time RVing
2015 Travel, 30 states, 10 national parks and over 100 nights.
If I knew it was going to be this much fun I'd started years earlier.
Nitroxron is offline   Reply With Quote
Old 01-06-2016, 12:59 PM   #16
Herk7769's Avatar
Ron & Sue Snavely
Is the "3 way splitter" that you are talking about a "wall plate"?
Old 01-06-2016, 01:57 PM   #17
3 way splitter
No it is a single in/3 out spliter in the wall behind the wall plate in the main area. It appears that the ANT/SAT gray cable comes to that wall plate and then feeds the splitter. All 3 lines take advantage of the 12v signal amplifier that is on the wall plate.
Old 03-08-2016, 06:10 PM   #18
ccsvolsfan's Avatar
I made a tracer end that I put on one of the outlets then use a voltmeter to check each outlet inside to trace where each went. Basically short one end of cable so meter can read which line you are testing.
ccsvolsfan is offline   Reply With Quote
Old 03-08-2016, 06:27 PM   #19
Herk7769's Avatar
Use care not to do this with the roof end of the antenna lead. There could be 12 volts there if the wall routing switch is on "roof" (amp power on).
Old 03-08-2016, 06:40 PM   #20
Left Coast
If you use an ohm meter, you don't need to power up anything..
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
antenna
