Old 08-23-2014, 08:48 AM   #1
2ndhome's Avatar
Shower leak on new 376 BHOK
Ok, I've read about the shower leaking, but took a chance on my brand new 5th wheel. Alas, puddle of water outside the shower. Is there an engineering reason behind not caulking the entire shower? I don't get it?Click image for larger version
Name:	ImageUploadedByForest River Forums1408801686.992821.jpg
2015 Sandpiper 376 BHOK
2ndhome is offline   Reply With Quote
Old 08-23-2014, 09:10 AM   #2
grumpy0374's Avatar
It's called "save a buck" engineering. Used commonely in the rv manufacturing process.
Had the same problem on our Lexi. Bought a tube of almond latex based bathroom caulk and re-did entire shower.
If you decide to go this route, very easy, but do not use any type of silicon, use a latex base caulk.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 08-23-2014, 09:20 AM   #3
2ndhome's Avatar
Thanks...caulk is on my husbands to do list!
Old 08-31-2014, 08:48 AM   #4
I had the same problem with my Sandpiper 30IOK. The shower track had alot of movement and didn't seem to be sealed very well. I used self tapping screws to secure the track down firmly to the shower and caulked around the track and shower. I also figured out that water was running down inside the shower track and leaking at the ends. I used some clear silicone to seal the ends of the track. So far it has held up and haven't had anymore issues. Hope this helps.
Bryon80 is offline   Reply With Quote
leak, show, shower
