Old 08-28-2014, 10:43 PM   #1
Going FullTime
wjhinds's Avatar
Slide troubles
Need some help. 346RET. when put the slides in, 3 of them, somewhere in the middle I get a click and I have to let off the button and press it again to keep putting them in. Sometimes it happens several times. What's the fix or place to start. Hydraulic slides. Fluid is good. Does it on battery, hooked to truck or 50amp.
Rhino
wjhinds is offline   Reply With Quote
Old 08-29-2014, 08:10 AM   #2
jtstromsburg's Avatar
I would guess the auto resetting fuses for the hydraulics are what is clicking. They could be bad, bye more than likely your battery is bad. I don't have hydraulic slides though, so just going on what I think.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 08-29-2014, 10:04 AM   #3
Going FullTime
wjhinds's Avatar
Battery is good. I will look into the breaker
Rhino
Old 09-01-2014, 05:24 PM   #4
paulj4400's Avatar
Slide troubles
Had the same problem on my 346 RET. Added another breaker to the bar and works fine.
Paulj Sent from my iPad using Forest River Forums
paulj4400 is offline   Reply With Quote
Old 09-01-2014, 05:28 PM   #5
paulj4400's Avatar
Name:   ImageUploadedByForest River Forums1409610502.718682.jpg
slide
