Old 04-22-2012, 09:27 AM   #1
slight bow in New 365saq awning
Picked up our new 365saq on 4/19. Had demo in bay of rv dealer service garage so we did not notice the 3/4" downward bow in the awning. Our last two rigs awnings were arrow straight. Is this a non issue in your opinions and normal to have wobble.
Also, with these remote control awnings has anyone ever added the center storage support. Especially for towing.
karznromz is offline   Reply With Quote
Old 05-21-2012, 07:22 AM   #2
Spencer Beaty's Avatar
I have a 2012 365 SAQ and after I read your post and a few others, I went out and looked at my own. It is probably not as straight as an arrow, but it is fairly strairght. I live in TN and have traveled to Myrtle Beach and a few other places fairly local, have not had any issues at this time.
Spencer Beaty
2007 F 250 SuperDuty
2012 Sandpiper 365 SAQ
Spencer Beaty is offline   Reply With Quote
Old 05-21-2012, 07:28 AM   #3
Herk7769's Avatar
If you feel like a little (OK, maybe a lot) mod time with your new camper; the Mega X57 might be what you need. It looks like it will straighten your bow and provide center support at the same time.
RV Awning Repair | MegaX57
HAM CALLSIGN - KC3FFW
Old 05-21-2012, 07:34 AM   #4
Long awning benefit from a center support. If you think it sags sitting still you should see the center movement going down a highway. Youroo!!
Old 05-22-2012, 02:01 PM   #5
I have a 2012 365 saq and have a slight bow also. My last camper had the same size awning and it also had a bow. Should not be a big deal!!
chiro is offline   Reply With Quote
Old 06-19-2012, 11:12 AM   #6
Herk7769's Avatar
May be the answer you seek.
Old 06-22-2012, 08:50 PM   #7
golfmedik's Avatar
I put a center awning support on my 355 and my 365 before they ever left the dealer. Both dealers I use in my area say that any awning over 16 feet in length should an awning support.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 06-22-2012, 10:46 PM   #8
leencharlotte's Avatar
I have a bow in my awning bar as well (power awning). Reached out to Dometic last week and this was their response
"According to the service manual roller will deflect between 1 to 5 inches.
If the roller is bent it will flop when opening and closing.
Open and close the awning and if it rolls smooth the bend you are seeing is standard deflection.
Awnings 22 foot and larger require the tension rafter awnings less than 22 foot the tension rafter is an option.
The main question is does the unit flop when rolling up and down, if so your service center needs to look at the awning."
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
365, 365saq, awning, led pad
