Old 09-19-2012, 09:41 AM   #11
TURBS's Avatar
Originally Posted by ttrost65
I based my design off your pics. Thanks! I also had the idea of making it detachable at the frame and a pad that would be pinched between landing gear pad and ground. Any thoughts on how that would work?
Could just make the upper mount pinned.
For that matter its a little more work but you could pin both ends for complete removal.
Old 09-19-2012, 10:22 AM   #12
AquaMan's Avatar
The pinch pad idea is more to keep from having to weld to the hydraulic pad. I'm figuring if I can create a pad the will envelope the foot pad of the hydraulics, it should do the same job as mounting directly to it.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 09-19-2012, 10:31 AM   #13
TURBS's Avatar
I'd like to see what you do with it.
