Added an image I made with the spreadsheet.
But will give link to my one-drives public map , that belongs to my hotmail.com adress with same username as in this forum ( so jadatis, like this to prefent spamm).
https://onedrive.live.com/?id=A526E0...26E0EEE092E6DC
You can navigate that and the submaps, many about tirepressure, and many in English, but also Dutch , I live and was born in Holland.
This picture is in the submap "all about tirepressure/Examples, together with others , also in kPa and both degr F and C .
The spreadsheet I did not put in there yet, so you cant make your own list.
But give the range you want in pressure and temperature, and I will make one.
But if you measured 80 psi at 78 degr F the temperature rising would even be more The lowest 87 psi then would mean an inside tire temp of 118 degr F , istead of 104 degr F. the highest 95 psi then would be 163 degr F instead of the 148 I first calculated for the 65 degr at 80 psi.
EDIT: uploaded the psichanchefortemp-spreadsheet, so you can play with it yourselfes.
I dont know if you are a little bit handy with Excell ( or CALC) , but mind that its not protected, so if you fill something in a cell with formula's , you overwrite them.
So if you store it on your computer, always save the original and give a new one a new name, so you can always go back to the original.
At the top the pressure calculation for tires with still the official European calculation.
Second the pressure/temperature playing part, with at the bottom the part I used here, for determining temperature.
below that I placed 2 charts, in wich the fatt printed pressures can be chanched to your needs, also the row in front with temperature you can chanche to your needs.
But dont touch the other cells, they contain formula's .
Best is to download it to your computer, because excell like programs in the claud , cant handle dropdownbars I used in the first part for loadindex/kg/lbs.
For other spreadsheets on my drive, also sheetprotection is used, to prefent you from overwriting formula's, and those cant also be handled by excel in the claud.
