Old 09-11-2015, 11:44 AM   #11
Fulltime family RVer
Originally Posted by 5erDriver View Post
My new 5er is 13,500 and change dry. By the spring and certainly before we hit the road next summer I will likely change up. Anything to reduce potential for trouble and damage on the road. The tires have gotten a little better since the DOT started to oversee them but not a season goes by without hearing several stories of blowouts.
Similarly sized fiver here- I had individual wheel weights done and found that I was over capacity on 1 tire and at capacity (3,400 vs. 3,420) on 2 others. I went nutty and upgraded my rims/wheels (17.5") + tires (load range H) for a much higher load carrying capacity. Turns out, going from 16" to 17.5" rims, you use a lower profile tire and my outer diameter actually shrunk by about 1/2". Which is good- my spacing is such that my tires were already really close.
ependydad is online now   Reply With Quote
Old 09-11-2015, 02:53 PM   #12
Airmech
ependydad, what 5ver do you have? I would have expected the bigger wheels and tires to make the gap worse. If you gained spacing, can you us the x chalks on there? do you even use chalks?
Pilot- Aaron, Copilot- Erica and Licker- Lizzy and Abby
5ver- TBA
2001 GMC 3500 Dually
smittyams is offline   Reply With Quote
Old 09-11-2015, 04:59 PM   #13
It's a Sabre 36QBOK. Very similar in layout to a Sandpiper 365SAQ (dual/opposing slide bunkhouse).
The reason that I gained space is because the sidewall height of the tire is much less. So, while it's a bigger wheel- it's still smaller on the outside. It took me a few readings from another guy before I finally understood.
I went from a 235/80/R16, lead range E. To a 215/75/R17.5, load range H.
And yeah, I use Rotochock brand chocks. Similar in concept, just different implementation.
Old 09-11-2015, 05:22 PM   #14
Witch Doctor's Avatar
Originally Posted by kcjoe1 View Post
I thought that I was taking good care of my China Bombs but a couple of weeks ago I found one that was low on air. MMMMmmmmm So, got home and took the tire off and took the soapy water to it. It took a couple of minutes to find it but sure enough right next to the wheel was a very small split in the tire. It didn't appear that there was any kind of road damage so I took it in to the RV dealer to ask him about it. Since we were just over our one year warranty he said " just buy another tire and put it on, the other ones will be just fine". I asked him if upgrading to an E rated tire would be better. " That's just overkill why would you want to do that?" He also mentioned that the C Rated tire that are on our 8289 WS are close to the max limit. MMMmmm Well, I decided to go with the E rated Carlisle radial trail tire from Discount tire and What a difference it made. We made a 1300 mile trip to ND and back and there is no more sway. The stiffer side walls made all the difference on how the truck and RV go down the road. I don't have to fight the wheel any more. I know too that Discount tire is all over the country so I know where to find a replacement should on be needed.
Happy Camper
Compare
Carlisle Radial Trail RH Trailer Tire
What is the tire PSI that you are running? If you didn't change the rims they are only listed for 60 lbs PSI stamped on the inside. Are E rated tires psi 80 lbs....
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-11-2015, 08:49 PM   #15
Airmech
I'll have to look them up. Have the x chocks on my list of need to buy items.
5ver- TBA
Old 09-12-2015, 08:22 AM   #16
kcjoe1's Avatar
gljurczk, I'm running 80 psi in my tires which is what their rated for. My rims are rated for 80 psi so I'm good to go.
2017 Arctic Fox 27-5L
2014 Rockwood 8289WS Diamond Package (SOLD)
2008 Dodge Ram 2500 SLT 4X4, Anarchy Tuning
kcjoe1 is offline   Reply With Quote
Old 09-26-2015, 11:47 AM   #17
denali15's Avatar
We got our new 2016 Sandpiper 371 in May. I have 2 tires that are failing already. It seems to me that they are under rated for the weight of the camper. 3520 each...
Name:	ImageUploadedByForest River Forums1443285864.046901.jpg
Name:	ImageUploadedByForest River Forums1443285946.904215.jpg
In the process of going through warranty with the dealer and upgrading them all to 14 ply's. Looking at the Sailun S637.
Anyone else experiencing problems with their tires?
denali15 is offline   Reply With Quote
Old 09-26-2015, 11:52 AM   #18
kcjoe1's Avatar
I have about 3000 miles on my Carlisle Radial Trail tires and what a difference the E rated tires made. My 8289ws pulls like a dream now. I'm happy I made the switch and I don't have to worry about WHEN I would get another blowout with the old (ha) tires.
Old 09-26-2015, 11:53 AM   #19
That's great they have put a better rim on, maybe they are not using Lionhead anymore for a supplier. I know mine are stamped 60 PSI on the inside.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-26-2015, 12:00 PM   #20
denali15's Avatar
They are still using Lionhead... Going through warranty on my tires right now.
tire, tires
